Sunny Truck was fitted with a regular (contact points) distributor through October 1989. From there on it was fitted with Electronic Ignition.
Versions
Contact Points Distributors
- 22100-G1610 DISTRIBUTOR ASSY 7510-7907
- 22100-W8511 DISTRIBUTOR ASSY 7907-8602
- 22100-G1910 DISTRIBUTOR ASSY 8602-8910
Coils
All used with ballast resistor
- 22433-U3100 COIL ASSY-IGNITION [HITACHI] 7510-8910
- 22433-U3110 COIL ASSY-IGNITION [HANSHIN] 7510-8910
- 22433-U3140 COIL ASSY-IGNITION [MITSUBISHI] 8504-8910
Resistor
- 22460-14606 RESISTOR-IGNITION COIL 7510-8910 Hitachi choice
- Hanshin HP5-13E10 12V-R(ヒタチ センタク シヨウ)
- 22460-14615 RESISTOR-IGNITION COIL 7510-8910 Hanshin choice
- 22460-14645 RESISTOR-IGNITION COIL 8504-8910 Mitsubishi choice
Electronic Distributors
22100-95W10
This is fitted to Datsun 1200 trucks from October 1989 through end of production in 1994. It is a nice unit with the transistor unit mounted in the distributor body, under the distributor cap. Late-model Electronic Distributor.
- 22462-52A60 COIL-IGNITION
- 22100-95W10 DISTRIBUTOR ASSY A12S 8910- ミツビシ (Mitsubishi) デストリビユーター (デストリビューター)
- 22100-95W12
- 22020-G5111 TRANSISTOR IGNITION UNIT [fits inside distributor]
- B2235-U7410 TAPE-SEAL, DISTRIBUTOR 7510- [a roll of tape]
- superceded by 22235-U7400 $3.39 USD
- 22301-95W10 CONTROL ASSY-VACUUM
- 22023-G5110 UNIT-SETTER
- 22201-22010 SCREW 7510- [fixing timing plate to distributor]
- 22180-71200 SEAL-O RING [distributor to engine block] $4.25 USD
- 22101-95W10 HOUSING ASSY-DISTRIBUTOR
- Condensor: None used
- ? 22107-95W10 GOVERNOR SET-DISTRIBUTOR
- 22115-95W10 SIGNAL-ROTO ASSY
- 22109-52H60 WEIGHT-GOVERNOR
- 22127-95W10 SPRING-GOVERNOR
- 22136-77A11 PLATE ASSY-BREAKER
- 22132-95W10 CAM SET
- 22229-95W10 SIGNAL SET
Cap & Rotor
- 22162-78A10 CAP ASSY-DISTRIBUTOR $27.36 USD
- 22185-95W10 PACKING [seal, cap to body]
- ? 04136-00211 SCREW
- 22157-23G15 ROTOR-HEAD $6.88 USD
Cap fits North America models:
- 1988-1990 Nissan Sentra with Mitsubishi distributor
- Oreillys.com E16 or GA16 Sentra
- Master Pro C672
- BWD C672
- Beck/Arnley 1746918
- Niehoff Ultra WA468A; Pro-Power WA468ACS
- Bosch 03320
- Standard Motor Products JH180
- AC/Delco E338A
- 1987-1988 Nissan Pulsar NX
Bosch 03320 CAP fits North America models:
- Nissan 1983-1994
- 1989-1990 Nissan 240SX
- 1990-1994 Nissan Pickup
- 1983-1990 Nissan Pulsar NX
- 1991-1993 Nissan NX
- 1984-1994 Nissan Sentra
- Subaru 1987-1991
- 1988-1989 Subaru DL
- 1990-1994 Subaru Loyale
- 1987-1989 Subaru GL
- 1987-1989 Subaru RX
- 1987-1989 Subaru GL-10
- 1987-1991 Subaru XT
- Suzuki
- 1989-1994 Suzuki Swift
22100-G5110
This Mitsubishi distributor has the small vacuum advance unit, which look like the original Datsun 1200 advance. G51 is the Applied model Code for Nissan Vanette C22 circa 1986 with A-series engine.
Discussion: Info on distrubutor please
22100-G5710 Mitsubishi T4T00571/T4T05712
- Vanette, (C22)
- Ignition system type: CB / electronic
- Ignition coil make/type: Han/H5-13-49
- Supply voltage: 4.1 + Volts with ballast resistor
- distributor cap: 22162-78A10
- rotor button: 22157-23G15
- Vacuum Advance unit: 22301-G5710
Other Mitsubishi T4T series:
- T4T11071 (22100-K8700 H25 Forklift engine?)
- T4T21693 (22100-K9800)
- T4T66871
- T4T66971
