Datsun 1000 Coupe -- you know you want one.
Advertising
Also see: Photo 4993.jpeg
Trim
KB10 was available in Deluxe and GL (Grand Luxury グランデ ラクジアリ) Trim levels.
Deluxe
Sunny Coupe: In Japan this was the DeLuxe & was the base model. It had a longer option list only because some of these options were standard equipment in the GL. The accessory list was the same as the GL.
Datsun 1000 Coupe DeLuxe: Offered in Australia only, these were pretty close in spec to the JDM DeLuxe model. Differences include 'some' Datsun badging as the deck lid emblem, & the grille emblem remained with the 'S' symbol from the original Sunny. NSW spec cars seem to have all come with a Tach, radio, two external mirrors, a heater & perhaps some other stuff, all of which were options in the Japan-market DeLuxe model. Other states may have varied the specs a little but the Aussie spec car was better equiped on the showroom floor than the equivalant Japan version. Japan cars had amber front park/blinker lenses while Aussie ones had white lenses. Everything on the brochure option list was available in Australia, including the wood rim steering wheel.
GL
Sunny Coupe GL: In Japan this had the sporty steering wheel & a few other trinkets to tart it up a bit & it was available with a floor shift auto trans as well as a short list of options & a loooong list of accessories.
GL grille was unique and GL black bullet mirrors
- 62303-25701 GRILLE-radiator C-G
Body Options
- F2674-25700 GUARD-bumper rubber (Op.) Coupe [front & rear]
- K7010-00001 BADGE-car, "SUNNY COUPE" (A) (op.) Coupe
- K7010-00001 BADGE-car, "Sunny Coupe" (B) (op.) Coupe
- K7010-00004 BADGE-car, "SUNNY COUPE" (A) (op.) Coupe
- K7010-00005 BADGE-car, "Sunny Coupe" (B) (op.) Coupe
- K7010-00003 PLATE-initial (A~Z) (B) (op.) Coupe
- 80900-25802 ASS'Y-FINISH, door (R.H.) (op.) Coupe
- 80900-H0301 ASS'Y-FINISH, door (R.H.) (op.) Coupe
- 80900-H0303 ASS'Y-FINISH, door (R.H.) (op.) Coupe
- 80901-25802 ASS'Y-FINISH, door (L.H.) (op.) Coupe
- 80901-H0301 ASS'Y-FINISH, door (L.H.) (op.) Coupe
- 80901-H0303 ASS'Y-FINISH, door (L.H.) (op.) Coupe
- K5040-00010 SET-VISER, side (stainless) (op.) Coupe [visor]
- K5040-00011 VISER-side (R.H.) (op.) Coupe
- K5040-00012 VISER-side (L.H.) (op.) Coupe
- K5040-00020 SET-VISER, side (plastic) (op.) Coupe [visor]
- K5040-00021 VISER-side (R.H.) (op.) Coupe
- K5040-00022 VISER-side (L.H.) (op.) Coupe
- 80010-H0301 SET-CYLINDER LOCK & KEY (op.) Coupe
- 87000-25803 COMP.-SEAT, driver reclining (check) (op.) Coupe '68
- 87050-25803 COMP.-SEAT, assistant reclining (check) (op.) Coupe '68
- 88300-25803 ASS'Y-CUSHION, rear seat (check) (op.) Coupe '68
- 88600-25803 ASS'Y-BACK, rear seat (check) (op.) Coupe '68
- 87000-H0322 COMP.-SEAT, driver reclining (check) (op.) Coupe '69
- 1969 seats have headrests
- 87050-H0322 COMP.-SEAT, assistant reclining (check) (op.) Coupe '69
- 88300-H0322 ASS'Y-CUSHION, rear seat (check) (op.) Coupe '69
- 88600-H0322 ASS'Y-BACK, rear seat (check) (op.) Coupe '69
- 88820-25725 SET-BELT, rear seat safety (op.) Coupe
- 88820-H0325 SET-BELT, rear seat safety (op.) Coupe
- 88820-25700 SET-BELT, rear seat safety (op.) Coupe
- 88820-H0300 SET-BELT, rear seat safety (op.) Coupe
- 86850-25700 ASS'Y-RETRACTOR, safety belt (op.) Coupe
- 62520-H0100 PLATE-closing, core support (R.H.) (op.) Coupe
- 62521-H0100 PLATE-closing, core support (L.H.) (op.) Coupe
Click each pic for larger view and discussion.
