Nissan Part Numbers
Revision as of 01:46, 6 January 2010; view current revision
Category: General Information
Nissan Part Numbers are comprised of two parts. The first part is the type of part. The part after the dash indicates the car model the part was originally designed for.
PN format: OOOOO-OOOOO
Format:OOOOO-OOOOO
Number:SectionCharacter-Part TypeDistinction
Indicates:major function of partminor classification of section-Applied model (1)difference between similar parts
(1) Applied model: "the part is originally designed for this model. However, it may be used widely over our models. Therefore, it does not always signify the applied model".
Also see: Nissan N.E.S. Bolt & Small Hardware Part Numbers
Section
10	ENGINE
20	ELECTRICAL
30	POWER TRAIN
40	AXLE
50	BRAKE
60	STEERING
70	BODY (SEDAN)
80	BODY (COUPE)
90	MISCELLANEOUS
Section Detail
10 Engine
001 ENGINE ASSEMBLY Raw Parts List, Engine Assembly
002 GASKET KIT Raw Parts List, Gaskets
003 CYLINDER BLOCK, FRONT COVER & OIL PAN Raw Parts List, Cylinder Block
004 CYLINDER HEAD, ROCKER COVER & THERMOSTAT Raw Parts List, Cylinder Head
005 EMISSION CONTROL DEVICE Raw Parts List, Emission Control
006 PISTON, CRANKSHAFT & CONNECTING ROD Raw Parts List, Piston & Crank
007 CAMSHAFT, VALVE, SPROCKET & CHAIN Raw Parts List, Camshaft
008 MANIFOLD Raw Parts List, Manifold
Sec.Group
10Engine complete section
11Engine section No. 1
12Engine section No. 2
13Camshaft & valve section
14Manifold section
15Lubrication section
16Fuel section No. 1
17Fuel section No. 2
18Engine control section
19Decomp & governor section
20Exhaust section
21Cooling system section
22Electric section No. 1
23Electric section No. 2
24Electric section No. 3
25Electric section No. 4
26Electric section No. 5
27Room heater & radio section
30Clutch group
32Transmission group
33Auxiliary gear box section
34Transmission control group
36Auxiliary brake section
37Propeller shaft group
38Final drive unit section
40Front axle section
41Front brake section
43Rear axle section
44Rear brake section
46Master cylinder, pedal &, piping group
47Power brake section
48Steering section
50Frame section
51Cross member section
54Front suspension section
55Rear suspension section
56Shock absorber section
57Spare tire section
60Body complete white body group
61Body front group
62Radiator shell & bumper section
63Fender section
64Hood ledge section
65Hood section
66Cowl section
67Dash section
68Instrument section
72Windshield section
73Roof section
74Floor section No. 1
76Body side section No. 1
78Rear fender section
79Back panel section
80Front door section No. 1
82Rear door section No. 1
84Trunk section
85Rear bumper section
86Front seat section No. 1
88Rear seat section No. 1
93Rear body section No. 1
95Body mounting section
96E. T. C. section No. 1
97E. T. C. section No. 2
99Car complete & tool section
Applied Model
Also see: Early Applied Model Codes
Applied Model codes (for A-engined vehicles)
TypeModel of Origin (chassis code explanation)
180B10
181VB10
182B10-D
183VB10-D
203B10-DA
248B10SF
258KB10
277B10 ('68)
278VB10 ('68)
277B10 ('68)
G01TB20S
G02LTB20STU ('69)
G03C20 ('70) C20S
G04C20H ('70) C20HS
G05VC20 VC20S VC20VS
G06KC20
G07C20 ('72)
G08C20
G09VC20
G10B120S ('71)
G11B120ST ('71)
G12B120STU ('71)
G13LB120ST ('71)
G14GB120S
G15VC20JS
G16B120T GB120T B121T GB121T
G19B122T GB122T
G20VC20JS
G28C120 Vanette
G51C22 Vanette
H01B10 ('69)
H02B10F ('69)
H03KB10 ('69)
H04VB10 ('69)
H05LB10U ('69)
H06LB10FU ('69)
H07VLB10U ('69)
H10B110S ('70.5) (S = Standard)
H11B110 ('70.5)
H12B110SR ('70.5) (R = 2-dr sedan)
H13B110R VB110S (V = Van/Wagon)
H14B110R ('70.5) VB110P (P = deluxe van)
H15VB110
H16LB110ST ('70.5)
H17LB110T ('70.5)
H18KB110 (K prefix = Coupe)
H19B110U (USA), B110N (Canada)
H20B110G (G = GL)
H21B110GR
H22KB110G
H23B110GTK (K suffix = Twin Carb)
H24B110GK (GX Sedan)
H25KPB110 ('71)
H26KPB110G ('71)
H27KPB110GR ('71)
H28PB110T ('71)
H29PB110GT ('71)
H30B110GTK ('71)
H31B110S ('72)
H32B110
H33B110GT
H34B110GTR
H35LB110
H36B110SR
H37B110R
H38B110GTR
H39LB110TRU
H40KB110
H41KB110G
H42KB110GR
H43VB110S
H44VB110
H45VB110SR
H46LB110TRU
H47KLB110U
H48B110
H50B210STKU
H51B210GT
H52B210GTK
H53B210R
H54B210GTR
H55KB210
H56KB210G
H57KB210GK
H58PB210T
H59PB210GT
H60PB210GTK
H61LB210T
H62LB210TRU A13 engine
H63KLB210
H64B210
H65VB210S
H66VB210
H67VB210SR
H68VLB210ST
H69KLB210U
H70LB110TRU ('73)
H71KLB110U ('73)
H72H B210 (A14 engine)
H74B210 Coupe A12 engine
H75B210 Coupe A14 engine
H77B210 North America? A14 engine
H78VB210 Super-DX or H
H79GB211 (L16)
H85B310 4-dr sedan 1200 & 1300 CT & DX
H856B310 4-dr sedan 1200 & 1300 GL trims N
H89B310 4-dr sedan 1400 & 1500 (except GXE & SGXE)
H92B310 4-dr sedan A15E (GXE & SGXE)
H86B310 2-dr sedans
H866B310 2-dr sedan 1300 GL
H87KB310 Coupe 1200 DX & 1200 SPT
H876KB310 Coupe other 1200 and 1300
H90B310 Coupe 1400 & 1500 carbureted & A15E
H92B310 Coupe A14E
H98WHB310 & WPB310 ??????? (California) except GXE & SGXE
H08WHB310 & WPB310 ??????? (California) A15E GXE & SGXE
H94VB310 & VB311 & VB312 4-dr wagon
H942VB310P & VB311P & VB312P
H96VHB310 & VHB311 & VHB312 1400 DX & SPDX wagons
H946VB310R & VB312R 2-dr wagon
H09VB312RJ & VHB312RJ 2-dr wagon DXA
MxxE-body (Cherry, Pulsar)
M01E10 ('71)
M02E10RT
M03E10T
M04E10SR
M05VE10SR
M06VE10R
M07VE10RT
M08PE10T
M09E10TU
M10LE10T
M11KPE10TK
M12E10HRT
M14KE10T
M15KPE10HT
M1651ZVLE10
M1752ZLE10
M1853ZVLE10
M1954VLE10
M20KPE10UT ('73)
M21LKPE10T
M22KPE10ST
W50A10 Sedan A14 DX
W51A10S Sedan A14 STD
W52A10H Sedan A14 GL
W53PA10, PA10A Sedan L16 DX
W54PA10H, PA10HA Sedan L16 GL
W55PA10HE, PA10HAE Sedan L16E GL-EL
W60KA10 Open Back A14 DX
W61KA10H Open Back A14 GL
W62KPA10H,KPA10HA Open Back L16 GL,GL-L
W63KPA10HE,KPA10HAE Open Back L16E GL-EL
W65VA10,VA10S,VA10H Van A14 STD,DX,GL
W70PA11G,PA11GF Z16
W71PA11G-E Sedan Z16E
W75PA11 Sedan Z16
W76PA11P,RA11 Auster Z16, Z18
W77KA11 Open Back
W78KPA11G Auster Hatch Back/Multi Back
W90UPA11 Hatch Back
Distinction
PurposeRangeMeaning
Similarity00-19
60-69
When parts are only slightly changed, or different color
Exc. Svc Use25-29
75-79
Repair kit/set used exclusively for service
Material00-19
60-69
Difference in materials
Processing00-19
60-69
For convenience of production line process, in case we can not use the original Part No.
LetteredA-ZExclusively reserved for service use
  • B50: Datsun 620 RHD
  • B93: Datsun 620 Truck RHD 7510-
  • B94: Datsun 620 Truck RHD 7605- Custom [extended cab]
  • B95: Datsun 620 Truck RHD
  • B96: Datsun 620 Pickup (coupe utility)
  • B64: Datsun 620 pickup LHD
  • G70:
  • G71: Datsun 620 Truck RHD 7809-
  • 210:
  • 216:
  • U01:
  • J01:
Example
Example: Nissan Part Number 40052-H1000
Sec. No.Character No.-Part Type No.Distinction No.
40052-H1000
Axle0-Front Axle-B110S('70.5)n/a
 052-Knuckle Arm RH-B110 Sedan, 1970-1/2
Reference: Datsun 1200 USA & Canada Parts Catalog Model B110 Series (C-0030U), 4th Overall Revision, December 1973
Quick ID
Look at this part of the part number: 00000-xxx00 The xxx part tells which car it was designed for. The first 5 digits is the part type, but you can tell that just by looking at the part.
SUNNY
  • 180, 181, 182, 183 (B10)
  • 209 (B10T)
  • 248 (B10SF)
  • 257, 258 (KB10)
  • 277, 278 ('68 B10)
  • H01-H03 ('69 B10)
  • Hxx numbers (B110/B210/B310)
  • W50 or W55 - A10 & B310
  • 95W late Sunny Truck
A-series FWD
  • Mxx is for F10/310
Datsun 510 designs are:
  • 210 through 299
  • A06 through A60
  • A86 through A95
  • N01 through N24
Datsun 620 Pickup
  • B50 through B99
  • G70, G71
Datsun 610
  • U01-U29
PATROL model 60 (1960-1980)
  • 440, 441, 442
Pickup
  • 10W 720 2WD?
  • 30W 720 4WD?
  • 04W 720 King Cab?
  • 03G
  • 31U VG30/VG20 Stanza?
  • 3Y5 Maxima C33?
