Pushrods
Revision as of 03:00, 3 February 2009; view current revision
Category: Engine Mechanical
Recall that pushrods come in two stock lengths:
  • ~152mm: short-deck engines (A10, A12, A12A, and late A13)
  • ~167mm: tall-deck engines (1974 A13, all A14 and A15)
  • 13238-H1000 ROD-push A12
  • 13238-H1001 ROD-push A12 from 7110, also 1980-1982 A13
Both sets interchange with each other as a set.
Tall-block engines use a different length:
  • 13238-H6201 ROD-push A14, A15
  • Datrats - Custom pushrods made to length from VW pushrods and using the A-series cup. They sit the turned down cup shaft on a ledge in the alloy. Custom made to your length and cheap.
Roller Pushrods
  • Many local speed shops can make custom pushrods
  • Yella Terra sold their pushrod tooling to "Head Stud Developments" in Melbourne
  • Crow Cams also provide pushrods to customer order, approx. 6.650-6.600 inches long (for A14/A15 subject to your needs) 0.080 wall thickness, Chrome Moly
  • Iskenderian Part# 1235L+.50. - custom pushrods for roller rockers (small block Chevy, +0.050 inch length), 8mm (5/16") ball ends
  • Isky also sells an adjustable pushrod ("universal" pushrod kit for Chevy smallblock)
