Air Filter
Round Type
- 8.88" (225 mm) O.D.
- 7" (178mm) I.D.
- 2.125 (54mm) height
- NISSAN 16546-18000 ASSY-ELEMENT,PAPER(VISCOUS) $7.99 USD [Sentra 1984-1990]
- BOSCH 73202 $4.82 USD
- FRAM CA353 $4.87 USD
- BECK/ARNLEY 0428219 $5.35 USD
- WIX 42906 $5.53, ACDELCO A392C $5.64 USD
- 1970-1972 Mazda 1200
- 1977-1978 Mazda GLC 1.3
- 1971-1972 Mercury Capri 1.6
- 1971-1973 Datsun B110
- 1974-1978 Datsun B210
- 1979-1982 Datsun B310
- 1983-1988 Nissan Pulsar 1.6
- 1982-1988 Nissan Sentra 1.5/1.6
- 1971-1978 Subaru H4
- 1987-1991 Subaru Justy
Air Breather Filter
2.25" x 1" x 1/4"
- BECK/ARNLEY 0421396 $1.63
- Datsun B110/B210/B310
- Datsun N10 A14/E15
- Datsun 610 1974-1976
- Datsun A10
- 521 L16
- 710 1974-1977
- 620 L16/L18/L20B
- 710 1980-1985 L20B/Z20/Z22/Z24
- 1983-1986 Pulsar 1.6
Fuel Filter
- NISSAN 16400-E3000 ASSY-STRAINER,FUEL [Sentra 1984-1985] $11.00 USD
- formerly 16400-A0600
- FRAM G3359 $2.54 USD
- WIX 33053 $2.54 USD
- BECK/ARNLEY 0438002 $2.90 USD
- ACDELCO GF466 $3.05 USD
- RYCO Z91 $6.95 AUD
- BOSCH 71909 $2.33 USD
Media: Paper Height: 3.42 in. Outside Diameter (Top): 1.879 in. Micron Rating: 10 Inlet: 7.0 MM Outlet: 7.0 MM Principal Application: Nissan (67-87), Toyota (76-77) 1976-1977 Celica 1975-1977 Corolla
Oil Filters
Australia:
- Z145A
- Z37
http://www.rockauto.com ELEMENT-oil filter, cartridge. Threads: 3/4-16 UNF, Outside Diameter: 80
- PRO-TEC 150 $2.43, BECK/ARNLEY 0418723 $4.41, BOSCH 72133 $4.41, WIX 51361 $4.67, ACDELCO PF34 $4.88, FRAM PH3639 $6.00
TIP: Use a Ford oil filter #F-1 on your 1200. You only need to use a rotary grinder to grind 1/4 inch off the engine boss. The rotary bit cuts cast iron like butter. Then it fits.
- bigger capacity
- In the US, it is less expensive than the small "import" filter
Pretty much any A-series filter fits. Or any with the same threads and diameter. Few are too long for the A12.
Original Length: 145, replaced by 115 length
- Nissan: 15208-H1010 115 height $8.27 USD
- formerly: 15208-13211 , 15208-13212 145 length
- Tokio FL-208(Y) 1300, 1500 C-201
- FRAM ExtraGuard PH3639
- Purolator #L30042
- Deutsch #D601
- Purolator PER42 (DATSUN,TOYOTA)
- Purolator L30042
- Pennzoil PZ8
- Champion PH2822,2825
- AC PF1026 (?)
Newer A-series filter PN 15208-H8920 (Length: 130)
- Tokio FL-208
- C-208
- CKO-1218
- SP-842
- FC 208
- 15208H8923
- T-3135
NISSAN SUNNY,CHERRY (Length: 100)
- FL-207
- 15208-H8916
- 15208-H8911
- 15208-H8994
- SP-929
- 15208-H8917
- 15208-H8912
- 15208-H8905
- 15208-H8904
- 15208-H8903
- 15208-H1011
- 15208-H1010
- Fram ExtraGuard PH3682
- Fram ToughGuard TG3682
- Fram DoubleGuard DG3682
- Fram X2 XG3682
- Purolator L24457
- Pennzoil PZ27
- Champion PH2827,2903 NISSAN,SUBARU
- AC Delco PF8903
- Wix 51361
- Champ PH2827
spin-on oil filter used on Nissan 200SX 4 cyl. 1.8L, 2.0L F.1.,& V6 3.0L F.1. engs., 300ZX V6 3.0L eng., M-10 Sedan 4 cyl. 2.0L F.1.eng, Maxima V6 3.0L F.1.eng, Micra 4 cyl, 1.2L eng., Pathfinder V6 3.0L F.1.eng.,Pickups V6 3.0L F.1.eng., Stanza 4 cyl. engs. Van 4 cyl. 2.4L F.1.eng.,Subaru 4 cyl. 1.6L & 1.8L, XT-6 Turbo 6 cyl. 3.0L Turbo. (Replaces: Nissan 15208-H8903; Subaru 15208-AA000) Equivalent: AC: PF1232 CHAMP: PH2827 FRAM: PH3682 MOBIL: MO-4457 MOTORCRAFT: FL-839 NAPA: 1361
B210, B310, F10
- Fram ExtraGuard PH46
- Purolator L10168 (Audi 5000 Turbo)
- AC DuraGuard PF34: PF34 #6437982 FITS: 74-82 DATSUN F10,210,B210,310; 78-80 FORD FIESTA L4-1.6L; 71-73 PINTO L4-1.6L; 72-75 CHEV LUV TRUCK; 83-90 MERCEDES-BENZ 4 CYL; 70-79 SUBARU; 86-90 TOYOTA VAN 2.2L, 69-80 W/KC, RC ENGINES, 81-84 STARLET, 84-85 TERCEL L4-2.0L. THIS FILTER REPLACES FRAM PH2825, PUROLATOR PER64, WIX 51034 & MOTORCRAFT FL13
