Parts from Datsun Bluebird 510 that fit Sunny.
B10
23164-H0100 BOLT-SETTING 23153-H0100 ASSY-NUT,PULLEY 31918-H0100 ASSY-INHIBITOR SWITCH 31931-H0101 ASSY-VACUUM,DIAPHRAGM 23127-H0300 ASSY-COVER,REAR 23230-H0300 ASSY-DIODE 23133-H0300 ASSY-HOLDER,BRUSH 23135-H0300 ASSY-BRUSH(F) 23118-H0300 ASSY-COVER,FRONT 23236-H0300 COVER-DIODE 23156-H0300 ASSY-BOLT,TERMINAL 23247-H0300 SLEEVE 23131-H0300 BOLT-THROUGH 23133-H0301 ASSY-HOLDER,BRUSH 23135-H0301 ASSY-BRUSH(E) 23131-H0301 BOLT-THROUGH
B110
16331-H1000 ASSY-COMPENSATOR 16331-H1000 ASSY-COMPENSATOR,IDLE 17312-H1000 DRAIN PLUG PACKING 17310-H1000 DRAIN PLUG 17312-H1000 DRAIN PLUG GASKET A7325-H1000 FUEL HOSE VINYLE 10X14X10,000 22157-H1000 ASSY-ROTOR,HEAD 22301-H1000 VACUUM CONTROL ASSY 22157-H1000 ROTOR-HEAD 22157-H1000 HEAD-ROTOR 30537-H1000 PIN BALL W/DRAWAL LEVER (THREADED TY 43252-H1000 SEAL-OIL,REAR AXLE SHAFT A7515-H1800 FUEL HOSE VINYLE 6X13.5X10.000 A7515-H1800 FLEXIBLE HOSE C (L=470) A7515-H1800 FUEL HOSE 14917-H1902 TUBE (IDLE COMPENSATOR TO CONNECTOR) 22167-H2300 CAP CLAMP SET 22136-H2300 BRAKER PLATE ASSY 22750-H2300 SCREW SET 22750-H2300 KIT-SCREW 22750-H2300 KIT-SCREW 40052-H2500 ARM-KNUCKLE RH 40053-H2500 ARM-KNUCKLE LH 40052-H2501 ARM-KNUCKLE RH 40053-H2501 ARM-KNUCKLE LH 13001-H2700 CAM SHAFT 22119-H2700 SET-COLLAR 13001-H2700SV CAM SHAFT 13001-H2710 CAM SHAFT 65601-H3525 SET-HOOD LOCK,MALE & FEMALE 65601-H3525 ASSY-MALE,HOOD LOCK 16510-H3900 ASSY-MOTOR,VACUUM 16585-H3900 TUBE (SENSOR TO CONNECTOR) 14959-H3900 TUBE (SENSOR TO CONNECTOR) 16580-H3900 ASSY-SENSOR,TEMPERATURE 16582-H3900 STOPPER 16059-H3910 VALVE-POWER #150 16059-H3910 VALVE-POWER #50
43070-H5000 SPACER RR AXLE 43215-H5000 BEARING RR AXLE 22100-H5900 DISTRIBUTOR (D411-59K)(ISO) L14 22100-H5900 ASSY-DISTRIBUTOR (D411-59K IS L14 22100-H5901 ASSY-DISTRIBUTOR L14 23100-H6200 ASSY-ALTERNATOR 12V 50A (LT150-05)FO
