Spark plug wires (leads) from many 4-cylinder engines will the Datsun 1200, although the wires might be a little long. It is easiest to buy a set specifically for the B110's A12 engine.
- Resistor type wires are recommended to prevent radio static.
- Large diameter wires (8mm, 9mm, etc) will have no effect unless you are running a non-stock high-energy ignition system.
- AcDelco 9044N (88861957) $13
- Autolite 86406 $15
- Borg Warner CH421SP $12
- Borg Warner CH421 $16
- Bosch 09065 $15
- Beck/Arnley 1754217 $14
- NGK 9393 (NGK NE67) $13
- Niehoff 12409NPS 7mm Black Silicone $13
- Niehoff 12409N 7mm ULTRA Black Silicone $14
- Powermax 700194 $10
- Xact 4620 $12
Spark plug wires (leads) from many 4-cylinder engines will fit, although the wires might be a little long. It is easiest to buy a set specifically for the B110's A12 engine.
For example, each set for B110 fits several other engines. It probably depends on exact how the manufacturer cut the wire lengths.
Beck/Arnley 1754217 Spark Plug wire set fits:
- B110 1971-1973
- 410 1965
- 411 1967
- 1600 Roadster 1966-1970
- 2000 Roadster 1968-1970
- 520 Pickup 1966-1968 (L16 or J13 engine)
- 521 Pickup 1969 (L16 engine)
Borg Warner CH421 fits:
- B110 1971-1973
- 520 Pickup 1968 (L16 engine)
- Fiat 124 1968-1969
- Triump Spitfire 1963-1969, 1972-1974
Nissan Competition
Source: 1984 Nissan Competition Catalog
- 99996-H2020 COMPETITION PLUG WIRE SET
- For racing purposes only
- [These are probably solid-core wires, which interfere with radio communications]
