Front Suspension Specification
Revision as of 07:16, 23 August 2011; view current revision
Category: Front Axle And Front Suspension
This page is for factory specifications. For modified settings, see Category:Suspension Modifications.
Wheel Alignment
Camber, Caster and Toe-in
See main article: Wheel alignment
Factory Front Suspsension Specifications
Coil Spring Specifications
'NA means North America
dataB110B210 1977 NAB210 1977 NA w/ACB310 1980/82 NAB310 1980/82 NA w/ACB310 1980 w/AC USA A12A rectangular headlight
Coil spring wire diameter10mm10.5mm10.8mm10.5mm10.8mm10.5mm
coil outer diameter110mm (4.33 in) 100mm (3.94 in)100mm (3.94 in) 100mm (3.94 in)100mm (3.94 in) 100mm (3.94 in)
Free length338mm +- 101977: 375mm
1974: 352.5mm
388mm375mm
357.5mm Canada A12A
366mm USA A12A rec. headlight model)
381mm
375mm Canada
375mm
Spring constant1.6kg/mm (89.6 lb/in) ??1.62kg/mm (90.7 lb/in) 1.65kg/mm (92.4 lb/in)1.62kg/mm (90.7 lb/in)
Kingpin Inclination (non-adjustable)
  • B110: 7
1974-up B120
B120 pickup:
Coil Spring
  • Wire diameter: 10mm (0.39 in)
  • Coil diameter: 100mm (3.94 in)
  • Loaded (normal load) length: 326mm (12.83 in)
  • Effective turn: 6.2
  • Spring constant: 1.6 kg/mm (90.0 lb/in)
Strut damper
  • Piston Rod diameter: 18mm (0.71 in)
  • Piston diameter: 25mm (0.98 in)
  • Stroke: 164mm (6.46 in)
Damping Force at 0.3m/sec (1.0 ft/sec)
  • Expansion/Rebound: 38-58kg (84-128 lb)
  • Compression: 17-27 kb (37-60 lb)
