Part Numbers Index
Revision as of 09:09, 7 January 2012; view current revision
This is a article index of Nissan Part Numbers for Datsun 1200. Note that discontinued (NLA) parts form Nissan can sometimes be found on eBay or from individual stores (NOS or "New Old Stock").
Use the SEARCH box at the FAR bottom of this page (scroll down) to search for specific parts.
Or click through the Index below.
Engine & Engine Control
Engine Engine assembly (all NLA)
Engine Gasket Kit
Cylinder Block & Oil pan
Cylinder Head & Rocker Cover
Engine Mounting
Piston & Crankshaft & Flywheel
Front Cover & Cylinder Fitting
Camshaft & Valve Mechanism
Manifolds
EGR
Emission Controls
Oil pump & Oil filter (oil strainer)
Exhaust Tube & Muffler
Water pump & Thermostat
Radiator
Accelerator Linkage
Fuel
Air Pollution Control
Vacuum Control (engine vacuum hose routing)
Carburetor
Fuel Throttle (See EGI fuel injection)
Fuel filter (fuel strainer) and Fuel Piping
Fuel Pump
Air Cleaner
Fuel Tank & Fuel Piping
Power Train
Clutch Accessory
Clutch Control
Automatic Transmission
* Accessory
* Torque Convertor & Case
* Oil Pump & Clutch
* Planetary Gear
* Control Valve
* Control Switch
* Fitting
Manual Transmission
* Accessory
* Transmission Case
* Transmission Gear
* Shift Control
* Transmission Control & Linkage
* Propeller Shaft
* Differential (Final Drive)
Misc
Maintainence & Tune-Up Parts
See: Parts_Sources#General Tune-up Parts
Electrical
  • http://www.rockauto.com
  • Alternator (Stock 35 amp): OE+ AL208 $18.04, BECK/ARNLEY 1860077 $35.79, BOSCH AL231X $54.99 <li>Alternator upgrades: See wiring article <li>Voltage Regulator: Nissan PN 23500-N3300 (same as 70-73 240Z, and 68-73 510) replaced by: 23500-29906 $103 USD (which also replaced 70-72 521 pickup) AIRTEX 1V1250 $18, ACDELCO E661 $40. GP Sorensen 265003 $48 <li>Starter:PN B3343-18005 TIP: Get a Bosch starter instead of the stock Hitachi starter. Or use a Mitsubishi starter from a B310. <li>Brake Stop Light Switch: Beck-Arnley 201-0288. Fits: Mitsubishi 1985, Dodge/Plymouth 1987-1988, Datsun/Nissan 1971-1984,Toyota 1965-1967 <li>Temperature Sending Gauge Switch: beck-arnley 201-0247 fits 1965-1986 Datsun/Nissan. <li>Ignition Coil: beck-arnley 178-8025 fits: Audi, Austin, chevrolet, toyota, etc etc etc. <li>Ignition Starter Switch: ACDELCO E1499A $19.87, BECK/ARNLEY 2011174 $19.91 <li>Key lock: ACDELCO E1495C IGN $24.79 LK W/ 7 TUMBLER LOCK CYLINDER <li>Distributor
      <li>coil ballast resistor: BECK/ARNLEY 1788000 $6.28, ACDELCO E1113, AIRTEX 6R1016 $10.19 <li>Condensor: BOSCH 02135 $3.06, Airtex 5H1015 $6.19, (for rear of dual-point sytem: Airtex 5H1016 $6.12) <li>Contact Set (Ignition Points): BECK/ARNLEY 1710391 $3.31, BOSCH 01134 $4.49, ACDELCO E179,
    </ul>
    Drivetrain
    Gearbox Bearings
    • Use a general bearing supplier, like CBC Bearings or SKF. They should be able to supply them if you can give them the numbers off the existing bearings, they have them in stock and far less dollars than Nissan. This is one case where buying from Nissan is not economical.
    Gaskets
    • Nissan: Head gasket set (includes head gasket, rocker cover gasket, intake & exhaust gaskets and thermostat gasket)
      • PN 11042-18027 (replaced PN 11042-H1025)
    • Nissan GX manifold gaskets
      • carb gasket: 16175-A5100
      • shield to manifold: 16174-H2300
      • Head to manifold : 14035-H2300
    • Tomei head and intake/exhaust gasket, GX gaskets, large bore head gaskets
    • Pitroad sells A-series gaskets, including 27mm round intake and and 35x29 (GX?) gaskests. See http://www3.ocn.ne.jp/~kyuusya/index-3.htm
    VALVES
    • PAECO
    • NAPA
    VALVE SPRINGS
    • wikipedia:BMC A-serie engine use the same valvespring sizes as the Datsun A-series -- partE S-002-8. Approx. $58.81 USD
    • Nissan Motorsport competition dual springs with aluminum retainers. These are for high-rpm use with a compatible camshaft.
    • Crane (discontinued) part# 902-0002 are a single spring rated at 80 lbs. closed at 1.531" installed height, and 209 lbs. at 1.131".
    • Crane Mini springs (for Austin Mini)
    • Iskenderian JA-006 inner springs (for dual spring use) are the right diameter but not enough pressure.
    Emission Control
      <li>PCV Valve: FRAM FV263 $1.73, BECK/ARNLEY 0450031 $2.24 PCV Valve, from $4.00 - $7.50. Available everywhere
      Interchange: Infiniti 1993 - 1997 J30 Subaru 1998-2002 FORESTER 2002 IMPREZA
      1971 - 1973 1200, 1972 - 1979 620 PICKUP, 1966 - 1970 1600, 1974 - 1977 710 , 1968 - 1970 2000 , 1980 720 PICKUP , 1977 - 1986 200SX , 1983 - 1986 720 PICKUP , 1979 - 1982 210 , 1977 - 1981 810 , 1970 - 1973 240Z , 1974 - 1978 B210 , 1975 - 1977 280Z , 1986 - 1989 D21 PICKUP , 1979 280ZX , 1976 - 1978 F10 , 1990 - 1996 300ZX , 1982 - 1984 MAXIMA , 1979 - 1982 310 , 1987 - 1989 PATHFINDER , 1967 411 , 1983 PULSAR ,, 1968 - 1973 510 , 1983 - 1990 PULSAR NX , 1978 - 1981 510 , 1982 - 1990 SENTRA , 1965 - 1968 520 PICKUP , 1982 - 1986 STANZA , 1969 - 1972 521 PICKUP , 1988 VAN , 1973 - 1976 610
    Induction
    • TWM Induction
      Weber dual DCOE intake manifold Part Number 8-3122 $569 (looks like oval ports and A12 mounting points)
    • AEM
      Fuel systems parts and more
      turbo plumbing
