A-series Distributor Comparison
Revision as of 05:57, 10 January 2012; view current revision
Category: Engine Electrical System
Do you want to fit the distributor into an early A10 or A12 engine? Or a later A12/A14/A15? The fit differently and so are not direct bolt-ins. But with simple modifications to the bolt-down bracket will fit each other.
Late engine block have a fastening bolt hole about 5mm further out from the dizzy bore hole. Plus the location and shape of the pad is different.
Early A-series (up to 1973) engines have the distributor-securing bolt hole almost straight forward of the dizzy bore hole.
Late (post-1973) A-series engines the distributor securing bolt to the rear of the dizzy bore hole.
Left: Early A-series plate (slots on opposite sides)
Right: Late A-series plate
  • Late style plate: 3 mm thick
  • Early style plate: 2 mm thick
Late vs Early A-series distributors
Late Style Advantage
Larger cap -- less chance to crossfire (important in humid climates)
Electronic Ignition is available too in native A-series format.
These are the normal reason one would want to fit a newer A-series dizzy in an older A-series block.
Using 1974-up distributor in older (1966-1973) A-series engines is possible by using the distributor plate with a slight modifications to the bolt-down bracket.
See: Using Newer Distributor
