Interior Shift Unit
Shift Knob
- 34919-H1100 LEVER-hand B110
- 34920-P4926 KNOB-CONTROL LEVER B210
Bushings
- 34907-25820 BUSH-HAND LEVER BRACKET
- B210: 34430-73001 BUSH-CROSS TUBE (2)
- 34462-18000 BUSH-SPHERICAL CROSS SHAFT
- B210: 34552-89900 INSULATOR
Raw Parts List
34902-H1900 ASSY-HAND LEVER & BRACKET 34903-H1900 ASSY-BRACKET HAND LEVER 34907-25820 BUSH-HAND LEVER BRACKET 34909-H1100 PACKING-HAND LEVER BRACKET 34915-H1100 ASSY-SUPPORT HAND LEVER 34946-H0300 SPRING-RETURN SELECT 34912-H1100 LEVER-HAND 34919-25820 KNOB-HAND LEVER 34919-H1000 KNOB-HAND LEVER 34923-25820 SCREW-HAND LEVER 34947-25820 PIN-SELECT 18136-61503 RING-SNAP"E" 34913-H1900 ASSY-SHAFT HAND LEVER 34434-89900 SCREW-LOCK 00851-21610 WIRE-LOCK 08360-82014 SCREW-MACHINE M8X1.25 34932-H2520 COMP-SHAFT ROD 34552-89900 INSULATOR-ROD 34419-04100 WASHER-SPRING 34485-14805 PIN-SPRING 34951-H2520 ASSY-CROSS SHAFT 34952-H1100 COMP-BRACKET CROSS SHAFT 34462-18000 BUSH-SPHERICAL CROSS SHAFT 34965-25820 COVER-OUTER RH CROSS SHAFT 34966-25820 COVER-INNER RH CROSS SHAFT 34463-14806 SPRING-RETURN CROSS SHAFT 34467-84700 BOOT-OUTER CROSS SHAFT 74941-89900 COVER-OUTER LH CROSS SHAFT 34936-H1100 COMP-SHAFT ROD LOWER 34938-25820 PIN-SHAFT ROD 34948-25820 RING-SNAP 'E' TYPE 34410-21000 TRUNION-GEAR SHAFT ROD 34552-89900 INSULATOR-ROD 01311-00021 WASHER-PLAIN 34419-04100 WASHER-SPRING 34485-14805 PIN-SPRING 08911-14010 NUT-HEX M10X1.25
Shift Linkage
Bushings
- 34462-18000 BUSH-SPHERICAL CROSS SHAFT (2) B110,B210
- 34552-89900 INSULATOR-ROD (4) B110,B210 [34410A, 34413B]
