The Hitachi H190 differential has a 190mm (7.49 inch) ring gear and can handle about 285 lb. ft. of torque, making it suitable for larger V6 or drag racing supercharged 1200s. H190 is the strongest live axle Hitachi fitted to Datsun cars (C200 from pickups is larger), and is available with lightweight aluminium carriers and a variety of stock ratios.
Gasket
Center section gasket for H190 carrier.
- 38320-B3002 Gasket-cover $4.13 USD
- 38320-B3000 GASKET-GEAR CARRIER
- 38320-25670 GASKET-GEAR CARRIER (10)
- 38320-25660 GASKET-GEAR CARRIER (10)
Compare to:
- 38320-04110 GASKET-GEAR CARRIER H165
Alloy
35 pound H190 center section.
- Datsun 510 Wagon
- Datsun Fairlady Roadster
- Datsun 320 pickup
Ratios
Widths
- Datsun 320 pickup: 50" in H190 diff
- Datsun V510 wagon: 53" in
Swap Notes
Several Datsun owners have swapped an H190 into the Datsun 1200s. The Datsun 320 pickup rear axle is one inch narrower than the Datsun 1200 unit.
Ratsun contains a nice photo essay with general information.
NOTE:
- There are at least four carrier types, which can only fit specific gear ratios
- There are various incompatible axle types/side gears, so swapping center sections doesn't always work
Side Gears
Nissan Competition
1984 Nissan Competition catalog.
S110
The ring and pinion sets listed will fit the 200SX/S110 (from 7/81).
38100-P0806 3.364 38100-P0706 3.545 38100-P0606 3.700 38100-P0506 3.900 38100-P0306 4.111 38100-P0206 4.375 38100-P0106 4.625 38100-Y4006 4.875 38100-B4003 5.143 38100-T3003 5.429
620/720
H190 RING & PINION SETS (FROM 5/76)
[Same as S110 ratios above]
Roadster
To install a 4.375, 4.625 or 5.125 ring and pinion into a third member equipped with a 3.700, 3.889 or 4.111 ring and pinion a 4.0mm/.157" ring gear spacer must be fabricated. Due to a smaller pinion shaft the 4.875 and 5.874 ring an pinion sts are interchangeable, but cannot be installed into third members equipped with other ratios.
[normal carriers] 38100-77700 3.700 R&P SET 38100-A5300 3.889 R&P SET 38100-25900 4.111 R&P SET
[high ratio carriers] 38100-26000 4.375 R&P SET 38100-77500 4.625 R&P SET 38100-37000 5.125 R&P SET
[special carriers] 38100-20600 4.875 R&P SET 38100-19901 5.874 R&P SET
Donor Cars
LSD
38420-A9980 3.70-4.11, 4.875-5.874
38420-16330 4.375, 4.625, 5.125
38420-B3400
38420-N9000 4-pinion 720 8004-8303 4-pinion S110 8204- HE41.FJ20
38420-41W00 2-pinion 720 8004-8303 2-pinion 720 8303-
510
510 Wagons and Vans came with a leaf-sprung rigid axles with H190 differential.
W510 Wagon V510-S Standard Van V510 Deluxe Van
Catalog C-091 38310-14800 COMP.-CARRIER, gear V&W 38100-22901 SET-GEAR, hypoid (37 T:8 T) [4.625] Van 38100-22600 SET-GEAR, hypoid (37 T:8 T) [4.625] Van 38100-22501 SET-GEAR, hypoid (35 T:8 T) [4.375] Wagon [W510] 38100-23500 SET-GEAR, hypoid (35 T:8 T) [4.375] Wagon
North America
USA and Canada
Datsun Roadster/Fairlady/Sports Datsun 410/411 Datsun 510 Wagon Datsun 320 Pickup Datsun 520 Pickup Datsun 620 Pickup Datsun 720 Pickup Datsun S110 (200SX) from 0781
38320-04110 GASKET-GEAR CARRIER 38320-04110 GASKET-GEAR CARRIER H165
320
Datsun 320 pickup uses a rear axles 50" in width with H190 diff -- narrower than a stock Datsun 1200 rear axle, making this a low-cost swap for high-power engines. But it uses 6-lug axles.
Roadster
38100-61000 RING & PINION 1.6L [1600] [3.889] 38100-25600 GEAR & PINION 1.6L [1600] [3.889] 38100-A5300 GEAR-SET HYP 1.6L [1600] 38100-77700 RING & PINION 2L [2000] [3.700]
410
1964-1967 Datsun 410/411 (Bluebird)
38100-14401 SET-GEAR,HYPOID(35T: OP.UT,LUT,WUT,WL UT 411 38100-61000 RING & PINION 1.6L 411 38100-25600 RING & PINION 1.6L 411 38100-A5300 GEAR-SET HYP 1.6L 411
510
510 Wagons came with a leaf-sprung rigid axles with H190 differential.
1967-1973 Datsun 510 (Bluebird)
38310-14600 CASE-CARRIER,GEAR -1171 38310-A3000 CASE-CARRIER,GEAR 1271- 38100-61000 SET-GEAR PINION 35/9 [3.889] WPLA WPZ WPZA WPX WPXA 38100-A5300 SET-GEAR PINION 0770-1171 * superceded 38100-25600 SET-GEAR PINION 35/9 [3.889] -0670 38100-P0501 SET-GEAR PINION 35/9 [3.889] 1271- 38100-A3800 SET-GEAR PINION 37/10 [3.700] WAGON FLOOR SHIFT 1271-
