Wheel alignment
Revision as of 07:32, 10 January 2012; view current revision
Categories: Suspension Modifications | Maintenance | Front Axle And Front Suspension
Also see Front Suspension Adjustment
Wheel alignment specifications for camber, castor and toe-in.
Modern alignment is recommended:
  • camber: -25' to 0°
  • caster: 2°05' to 3°10'
  • toe-in: 4mm
Since the strut-type suspension is normally non-adjustable, changes to the camber & caster may be requires modifications. See Front Suspension Adjustment.
B110
The stock settings follow. These are old-fashioned settings, designed for old road standards.
All
Steering angle In: 43°
Steering angle Out: 36°
Sedan & Coupe
Camber: 5' to 2°05'
Caster: 20' to 1°50'
Toe-in: 4-6mm (0.08 to 0.32 inch)
King pin inclination: 7°55'
Van
Camber: 45' to 1°45'
Caster: 1°05' to 2°05'
Toe-in: 5-7mm (0.20 to 0.28 inch)
King pin inclination: 7°45'
Van with Heavy Duty Spring
Caster: 40' to 1°40'
B310
B310 12" wheel models
camber: -25° to 1°05'
caster: 1°40' to 3°10'
toe-in: 0 to 2 mm (0 to 0.08 inch)
kingpin inclination: 7°40' to 9°10'
turning angle inside: 41° to 45°
turning angle outside: 33.5° to 37.5°
B310 13" wheel models
camber: 0° to 1°30'
caster (wagon): 1°55' to 3°25'
toe-in: 1 to 3 mm (0.04 to 0.12 inch)
kingpin inclination: 7°50' to 9°20'
turning angle inside: 38° to 42°
turning angle outside: 31.5° to 35.5°
