Brake Bleeding
Revision as of 02:00, 12 January 2012; view current revision
Category: Brake System
  1. Bleed the master cylinder (sometimes called "bench bleeding" but can be done while installed in the car)
  2. Bleed the front wheel cylinders
  3. Bleed the rear wheel cylinders
Method 1
The fluid prevents air from going back up into the cylinder.
  1. Put about 1" new fluid in a clear glass
  2. put a hose from the bleeder to the bottom of the glass, making sure the new fluid covers end of hose
  3. Crack the bleeder slightly
  4. pump the brake pedal while you watch the glass. When air bubbles stop coming out, it's done.
  5. tighten bleeder
  6. top-up the master cylinder
  7. bleed the next wheel cylinder
Method 2
Discussion: Bleeding the brakes.....on your own
7952_4c1336c80adaa.jpg 7952_4c133737e7ed1.jpg 7952_4c13374889a68.jpg 7952_4c13377c7fec5.jpg 7952_4c13384f4c72a.jpg 7952_4c13397d3c3cc.jpg
Traditional Method
  1. loosen bleeder
  2. push brake pedal down and hold it down
  3. tighten bleeder
  4. let brake pedal up
  5. repeat until clean, steady stream fluid comes out
