Shortening struts
Revision as of 06:53, 23 January 2012; view current revision
Category: Suspension Modifications
If you lower your car very much, the strut will start bottoming out. To mitigate this, shorten the strut. It's easy and can be done with or without welding.
Remove the spring, then grind the spring perch free from the strut tube.
Cut the strut to the length you want. For a three-inch lowering job, cut the strut three inches.
Then place the spring perch where you want it and fasten securely. You can have it re-welded or use a commercial-grade shaft collar.
Cutting Strut Tube
Cut down, welds ground off
Ready to prime (use weld through primer to seal under where the spring seat will go)
Primed, now ready for fastening the spring seat
Fasten Lower Spring Seat
You can place the spring perch where you want it and fasten securely. You can have it re-welded or use a commercial-grade shaft collar.
See main article: Fastening Spring Seats
