Comparison of Spark Curve parts for 1978 B210 North American models. It includes six different curves for CAL, CAN, FED and AT versus 4-speed (MT) versus 5-speed (FU) models.
Distributor
1978 B210 (all use A14 engine) CAN MT (D4A7-02) 0°/70mmHg-15°/300mmHg 0°/750-10°/2400 RPM CAN AT (D4A7-03) 0°/70-6.5°/300 0°/750-10°/2400 CAL MT (D4F5-03) 0°/105-15°/390 0°/550-14°/2300 FED MT (D4F5-03) "" GFU MT (D4F7-01) 0°/80-14.5°/330 0°/550-14°/2400 CAL AT (D4F5-05) 0°/105-9°/300 0°/550-14°/2300 FED AT (D4F6-03) 0°/170-6.5°/300 0°/550-14°/2300
Initial Timing
1978 B210 A14 USA MT 10°/700 RPM CAN MT 10°/700 USA FU 5°/700 CAN AT 10°/650 CAL AT 10°/650 FED AT 8°/650
Advance Parts
1978 B210 FED MT 22108-H7300 SHAFT ASSY 22109-A5500 WEIGHT GOVERNOR 22110-H7301 SET GOVERNOR SPRING 22301-H7360 VACUUM CONTROL ASSY
1978 B210 FED AT 22108-H7300 22109-A5500 22110-H7301 22301-H7205 VACUUM CONTROL ASSY
GFU 22108-H7300 22109-A5500 22110-H7780 22301-H7680 VACUUM CONTROL ASSY
CAL MT 22108-H7300 22109-A5500 22110-H7301 22301-H7360
CAL AT 22108-H7300 22109-A5500 22110-H7301 22301-H7365
CAN MT 22108-M5600 22109-A5500 ??? 22110-H7601 22301-M2361 <2> 22301-H7201
CAN AT 22108-M5600 22109-A5500 ??? 22110-H7601 ?????-?????
Mechanical Advance
1978 B210 CAN MT (D4A7-02) 0°/750-10°/2400 RPM CAN AT (D4A7-03) "" GFU MT (D4F7-01) 0°/550-14°/2400 CAL MT (D4F5-03) 0°/550-14°/2300 FED MT (D4F5-03) "" CAL AT (D4F5-05) "" FED AT (D4F6-03) ""
0°/550-14°/2300 22108-H7300 SHAFT ASSY 22109-A5500 WEIGHT GOVERNOR 22110-H7301 SET GOVERNOR SPRING
0°/550-14°/2400 22108-H7300 22109-A5500 22110-H7780 [heavier spring]
0°/750-10°/2400 22108-M5600 22109-A5500 ??? 22110-H7601
Vacuum Advance
mmHg CAN MT (D4A7-02) 0°/70-15°/300 CAN AT (D4A7-03) 0°/70-6.5°/300 GFU MT (D4F7-01) 0°/80-14.5°/330 CAL AT (D4F5-05) 0°/105-9°/300 CAL MT (D4F5-03) 0°/105-15°/390 FED MT (D4F5-03) "" FED AT (D4F6-03) 0°/170-6.5°/300
VACUUM CONTROL ASSY 22301-H7360 0°/105-15°/390 22301-H7205 0°/170-6.5°/300 22301-H7680 0°/80-14.5°/330 22301-H7365 0°/105-9°/300 22301-M2361 0°/70-15°/300 ?????-????? 0°/70-6.5°/300
