Advance Comparison
Revision as of 11:59, 28 April 2012; view current revision
Category: Ignition
Comparison of Spark Curve parts for 1978 B210 North American models. It includes six different curves for CAL, CAN, FED and AT versus 4-speed (MT) versus 5-speed (FU) models.
Distributor
1978 B210 (all use A14 engine)
CAN MT (D4A7-02) 0°/70mmHg-15°/300mmHg 0°/750-10°/2400 RPM
CAN AT (D4A7-03) 0°/70-6.5°/300 0°/750-10°/2400
CAL MT (D4F5-03) 0°/105-15°/390 0°/550-14°/2300
FED MT (D4F5-03) ""
GFU MT (D4F7-01) 0°/80-14.5°/330 0°/550-14°/2400
CAL AT (D4F5-05) 0°/105-9°/300 0°/550-14°/2300
FED AT (D4F6-03) 0°/170-6.5°/300 0°/550-14°/2300
Initial Timing
1978 B210 A14
USA MT 10°/700 RPM
CAN MT 10°/700
USA FU 5°/700
CAN AT 10°/650
CAL AT 10°/650
FED AT 8°/650
Advance Parts
1978 B210 FED MT
22108-H7300 SHAFT ASSY
22109-A5500 WEIGHT GOVERNOR
22110-H7301 SET GOVERNOR SPRING
22301-H7360 VACUUM CONTROL ASSY
1978 B210 FED AT
22108-H7300
22109-A5500
22110-H7301
22301-H7205 VACUUM CONTROL ASSY
GFU
22108-H7300
22109-A5500
22110-H7780
22301-H7680 VACUUM CONTROL ASSY
CAL MT
22108-H7300
22109-A5500
22110-H7301
22301-H7360
CAL AT
22108-H7300
22109-A5500
22110-H7301
22301-H7365
CAN MT
22108-M5600
22109-A5500 ???
22110-H7601
22301-M2361 <2> 22301-H7201
CAN AT
22108-M5600
22109-A5500 ???
22110-H7601
Mechanical Advance
1978 B210
CAN MT (D4A7-02) 0°/750-10°/2400 RPM
CAN AT (D4A7-03) ""
GFU MT (D4F7-01) 0°/550-14°/2400
CAL MT (D4F5-03) 0°/550-14°/2300
FED MT (D4F5-03) ""
CAL AT (D4F5-05) ""
FED AT (D4F6-03) ""
0°/550-14°/2300
0°/550-14°/2400
22108-H7300
22109-A5500
22110-H7780 [heavier spring]
0°/750-10°/2400
22108-M5600
22109-A5500 ???
22110-H7601
Vacuum Advance
mmHg
CAN MT (D4A7-02) 0°/70-15°/300
FED MT (D4F5-03) ""
VACUUM CONTROL ASSY
22301-H7360 0°/105-15°/390 $71 USD
22301-H7205 0°/170-6.5°/300 $63 USD
22301-H7680 0°/80-14.5°/330 $93 USD
22301-M2361 0°/70-15°/300 [superceded by 22301-H7680]
22301-H7365 0°/105-9°/300 $75 USD
?????-????? 0°/70-6.5°/300
Other B210/B310
22301-H6200 $62 USD
22301-H9100 $60 USD
22301-H7200 [superceded by 22301-H9100]
22301-H8300 $51 USD
22301-H9501 [superseded by 22301-H9801] DUAL
22301-H9801 $73 USD DUAL
22301-H9806 $61 USD
22301-H8700 $66 USD
22301-H9160 $60 USD
22301-H9100 $60 USD
22301-H7106 NLA
22301-H9106 $51 USD
Looks same
22301-23M00 1982 DUAL N10 FED.E15S.?
* 22301-24M00 B11 (FED.2S+FED.4S+FED.C+FED.W).E15S.AT
22301-23M07 1983 DUAL B11 E15S
22301-34M00 1982-1983 N12,B11 FED.E16S.AT
* 22301-34M01 ""
22301-33M01 1983-1985 B11, N12 E16S.MT.various
* 22301-33M02
* 22301-33M04
22301-32M01 1983-1985 B11,N12 E16S.AT.?
22301-D3300 1984 T11 CA20E
22301-D2100 1983-1984 T11 CA20S.MT
22301-D2106 1983-1984 T11 FED.CA20S.AT
22301-D1701 1982 T11 CA20S.MT
22301-D1706 1982 T11 FED.CA20S.AT
22301-10W21 1983-1984 720 Z24
* 22301-10W22
22301-06W03 1981-1982 720 2WD.Z22.MT +FED.Z22.AT
22301-W8800 1980
* 22301-W8801
22301-N3602 1974
22301-N4200 1975-1978
22301-N4700 1977-1979 S130 FED.L28E.MT
22301-18R05 1985-1986 M10 CA20E.AT
22301-47W01 1981 720 (CAL.T.REG+CAL.K/CAB+CAL.T.LONG).4WD.Z22
22301-07W03 1982-1983 720 CAL.(T+K/CAB).Z22.AT +FED.(T+K/CAB).4WD.Z22
* 22301-07W05
22301-B9800 1978-1980 720 CAL.120B.MT
* 22301-B9905 720 (C.HD/T.HD/LB+CAL.HD/T.C&C).L20B
* 22301-C6001
22301-20W21 1983-1985 720 (T+K/CAB)FED.2WD.Z24
* 22301-20W22
22301-N5906 1977-1979
22301-W8905 1980
Honda 30104-PE1-840 1986-1987 CRX HF
Honda 30104-663-791 1978 Accord, 1978-1979 Civic Wagon
