Wheel Studs and lug nuts for Datsun 1200 are M12x1.25 thread. Nuts are 19mm hex head (~3/4 inch).
Discussion: extra long wheel stud info
Thread: M12 x 1.25
Front, Disc Brakes
- Head Code: 240
- Knurl Diameter: 13.00mm
- Thread Pitch: Right
- Shoulder Length: 10mm
- Thread Size: M12-1.25
- Length: 32mm
- Type: Serrated Stud
Rear
- Nissan Part Number 40222-18000 BOLT-HUB ROAD WHEEL (B110 & B120)
- Head Code: 242
- Knurl Diameter: 12.56mm
- Shoulder Length: 11.5mm
- Length: 37.5mm
- Type: Serrated Stud w/Clip Head
Front, Drum Brakes
40222-18000 BOLT-hub (for front drum brake)
Front, Disc Brakes
- Nissan 40222-22001 BOLT-hub (for disc brake)
- Dorman 28321 (Head Code N)
- Dorman 610-240 (610240)/610-2401/98320/983201
- Wagner/Guardian/One Source BD60980 [knurled] at RockAuto
- Raybestos 27792B [knurled]
Stock Fits
- 1971-1973 Datsun 1200
- 1980-1981 Datsun 810
- 1970 Datsun 2000
- 1974-1975 Datsun B210
- 1984-1986 Nissan 200SX
- 1986-1994 Nissan D21 Pickup
- 1979-1982 Datsun 210
- 1976-1978 Datsun F10
- 1970-1973 Datsun 240Z
- 1998 Nissan Frontier
- 1974-1975 Datsun 260Z
- 1982-1984 Datsun Maxima
- 1975-1978 Datsun 280Z
- 1987-2006 Nissan Pathfinder
- 1979-1983 Datsun 280ZX
- 1995-1997 Nissan Pickup
- 1984-1986 Nissan 300ZX
- 1983 Nissan Pulsar
- 1968-1973 Datsun 510
- 1983-1986 Nissan Pulsar NX
- 1973 Datsun 610
- 1982-1986 Nissan Sentra
- 1977-1979 Datsun 620
- 1982-1986 Nissan Stanza
- 1980-1986 Datsun 720
- 2000-2006 Nissan Xterra
- 1997-2003 Infiniti QX4
Head Code N Fits
- 1972-1973 Datsun 1200
- 1984-1988 Nissan 200SX
- 1986 Nissan 720 Pickup
- 1986-1993 Nissan D21 Pickup
- 1987-1993 Nissan Pathfinder
Extra Long
- NISMO 40222-A0220 [2" long/51mm]
- For A-series front, 510, rear of FWD models, many more
Would this work? 12.9 instead of 13.0 mm knurl. The 510 and Z-car guys use them to replace the front lugs (which are the same as B110).
* 40222-15C01 GC22 Van $2.12 USD each * 43222-0B001 V40 Quest $9.47 USD each * NAPA/Balkamp 6412785 $2.29 USD each * Dorman 610-403 (610403) $1.34 Rockauto Type: Serrated Stud Thread: M12-1.25 Knurl Dia.: 12.90mm Length: 45.5mm Shoulder Length: 15mm * Infiniti J30 front 1995-93 * Nissan VAN Front 1988-87, From 1/88 * Nissan QUEST Rear 1998-93, From 1/88
Rear
NOTE: Fits B110, B120, B210, B310. Also B110 front drum
For H145, H150 and H165
* Nissan 40222-18000 BOLT-HUB ROAD WHEEL (B110 & B120) $3.60 USD * Dorman 98340/983401/610242 RockAuto * Dorman 28340 (Head Code D.4.0) * NISMO 40222-H5020 [2" long/51mm] * Wagner BD60951 [non-knurled] * Raybestos 9340B [non-knurled]
Application: * B110 * B120 * B210 * B310
Nuts
Lug Nuts for steel wheels
- Nissan 40225-27700 NUT-ROAD WHEEL
- NISMO 40224-R1120 NUT/TAPERED
- RAYBESTOS Professional Grade 10018N
- Dorman 711406 AutoGrade/RB 711-406-005 Open End-Bulge Seat
- Dorman 611064 Autograde/RB 2029933 (09140-12026, 09159-12020, 28171XA00A, 30015781, 40225-27700, 6230 06002, 6230 06003)
- Standard Open Nut
- Thread M12-1.25
- Hex Size 19mm
- Length 16mm
- Seat Angle 60 deg.
- Finish Chrome
- Dorman 611174 AutoGrade/RB 611-174-006 Acorn, Bulge Seat, Hex Size E
- Dorman 611099 AutoGrade/RB 611-099-006 Acorn, Hex Size A, 1-pc
- 40224-21001 B310
- 40224-21001 B310
- 40224-M7200 B310 Acorn style
- 40224-M7210 B310 Acorn style
- ALLOY WHEELS
- NISMO 40224-E7200 NUT/SQUARE SHOULDER
- For most alloy wheels. Shank: 19mm (0.748"), Length: 14mm (0.551")
- 40224-R4626 NUT SET-WITH LOCK (FOR ALMI) B310
- 40224-R4670 NUT-ROAD WHEEL,FOR ALUMINIUM B310
- Dorman 611103 AutoGrade/RB kit611-103 Mag-Short Shank
- Dorman 611107 AutoGrade/RB 611-107-006 Mag-Standard (2 pc. construction)
Alternatives
Reportedly fit 1200 disk brakes.
S13 (1989-1994 Silvia) Studs:
- Dorman 610320/98350/983501/983551 (S13 Rear & Front, flat head)
- Head Code: 320 (19mm diameter?)
- Knurl Diameter: 12.83mm
- Shoulder Length: 14mm
- Length: 41.5mm (~47mm overall)
Fits: Most Datsun/Nissan 1970-2006
Also see: Dorman 28355 (Head Code NS, rounded), somem Datsun/Nissan including S13.
Extra-long Repco Stud S4570:
- 77mm long overall
- 72mm long minus head
- 19mm dia head
- Use with Repco Nut: NN421
SSR Mark I and Mark II
SpeedStar Wheels Mark 1 or Mark 2 requires a special nut. Imported from Japan. About $5 each in USA (includes washer). MK-I or MK-II M12 x 1.25, they are NOT tapered, but are shank nuts, although a different diameter than most.
USA: http://www.more-japan.com/ssr-mk-i-mk-ii-lug-nut-m12x1.5-w-washer.html
- 17.1mm shank diameter
- 19mm depth
NiceProducts (Australia) part number M300
Locking Nuts
Magnetic Locks
