The room lamp, also known a dome light.
Car
These parts are the same for both B110 and B210.
- 26410-H1000 ASS'Y-LAMP, room $19.80 USD
- 26411-H1000 LENS $8.13 USD
- 26414-H1000 BODY
- 26736-89902 BULB $2.38 USD
- 89-10412-12/08510-41212 SCREW TAPPING M4 (2) $0.80 USD
510 Lamp
510 lamp is a different style and bolts into B210, so may fit B110.
- 26410-23101 ASSY-LAMP ROOM USA -0968
- 26410-A0800 ASSY LAMP ROOM SEDAN USA 1068-
- 26736-89901 BULB 12V 10W
- 26411-23101 LENS ROOM LAMP
Pickup
Two wires:
- Red: bulb 12V
- Black: earth/ground
521 Lamp
Same as 1200 Pickup. IKI brand.
26400-04100 ASS'Y-LAMP, room 26410-04400 ASS'Y-LAMP, room * 26411-04100 LENS * 26715-89900 BULB (12V 6W) * 5-10813-1 SCREW-machine (2)
- 26410-G1000 LAMP ASSY-ROOM -7803 IMASEN
- 26410-04100 LAMP ASSY-ROOM -7803 IKI
- 26410-04400 LAMP ASSY-ROOM 7804- IKI
- 26073-30001 BULB 6W
- 26411-G1000 LENS -7803 IMASEN
- 26411-04100 LENS 7804- IKI
- 08510-41212 SCREW
- 01451-00171 SCREW 8910-
The room lamp has one side of the lamp (RL wire) always hot from the L wire of the fuse box. The switch has three positions:
- Off
- Auto (center)
- On
In the auto position, the light is grounded by the Door Switch (BR wire in a-pillar). Usually only the driver's side door has a switch. In the ON position, it is grounded through the ground wire in the headliner.
