520
Revision as of 06:09, 18 November 2012; view current revision
Datsun 520 Truck was produced from 1965 to 1968. The minor model change came in late 1968 with the updated 521. The 521 and L521 continued to use the J13 engine until the Premium-engined 521 was introduced for North America (PL521).
Model Variation
520 Truck
L520 Truck for LHD (left-hand-drive)
L520U Truck, LHD for USA
G520 Long wheelbase (long body) Truck
U520 Double-cab Pickup (2-dr with back seat, 1-piece body/bed)
V520 2-dr Van (wagon)
521
G521 Long Body Truck (long wheelbase)
N-engined (J15) N521, GN521
P-engined (L16) PL521
U521 Double-cab pickup 2-dr 1968-1969
UN521 1970 N-engined
V521 Van 2-dr 2-dr 1968-1969
VN521 1970 N-engined
1965 520 2-eye
520
G520 Not Available
U520
V520
1968 520 4-eye
1968 521 4-eye
Wheelbase
521 has 45 mm longer wheelbase than equivalent 520 version.
521 2530 mm
G521 2770
U521 2530
V521 2630
Track
L521
* Front: 1267 mm
* Rear: 1260 mm
Length
521 is 45 mm longer than equivalent 520 variation (SWB, LWB, D/C or Van)
Overall length (not including rear bumper)
mm
520  4245 w/o rear bumper
G520 4635 w/o rear bumper
U520 4300 including rear bumper
V520 4300 including rear bumper
521  4290 w/o rear bumper
G521 4680 w/o rear bumper
U521 4345 including rear bumper 4270 without
V521 4345 including rear bumper
Fuel Economy
All models (520 & 521: Truck, Long Body, Pickup, Van)
* J13: 15.5 kg/l
* J15: 14.5 kg/l
Weight
 520  960 kg
U520 1035
V520 1055
 521  975 kg
G521 1010
U521 1050
V521 1070
Wheel & Tire
521 - 14"
* front 6.00-14 6 ply LT
* rear: 6.00-14 8-ply LT
U521/V521
* all 5.60-14 6 ply LT
Gearing
Floor Shift
521T (floor shift)
F4W63
1st 3.657
2nd 2.177
3rd 1.419
4th 1.000
Rev 3.638
J13: 4.875 final drive
J15: 4.625
L16: 4.375
Remote Shift
521 (column shift)
R4W63 #1
1st 4.243
2nd 2.558
3rd 1.589
4th 1.000
Rev 4.367
Final Drive
4.625 N521U/GN521U, NL521/GNL521
4.375 UNL521, VN521
Remote Shift Wide
521 (column shift)
R4W63 wide ratio
1st 5.000
2nd 3.014
3rd 1.685
4th 1.000
Rev 5.146
Final Drive
4.875 521U/G521U, L521/GL521
4.625 U521/UL521, V521U/VL521
Load Capacity
520U/520/L520/L520T 2205 pounds export models
 520 1000 kg
U520 6 passenger + 400 kg
V520 3 passenger + 500 kg
     5 passenger + 300 kg
 521 3 passenger + 1000 kg
G521 3 passenger + 1000 kg
U521 6 passenger + 400 kg
V521 3 passenger + 500 kg
PL521 2 passenger + 454 kg (1000 lb)
Transmission
JDM 521 Truck did not come with Floor Shift option. -T suffix indicates Floor Shift 4-speed.
R4W63 Remote Shift (column shift) 4-speed
521/L521
G521/GL521
N521/NL521
N521U/GN521/GNL521
F4W63 Floor Shift 4-speed
L521T/NL521T
GNL521T
U521/UL521/UNL521
V521/VL521/VNL521
PL521TU/PL521TN
Engines
520 J13 engine
521 J13 & J15 engine
L521  J13 engine
PL521 L16 engine
J13
bore: 73 mm
stroke: 77.6 mm
capacity: 1299 cc
compression: 8.2:1
Horsepower: 62 PS @ 5000 rpm
Torque: 10.0 kg-m @ 2800 rpm
J15
bore: 78 mm
stroke: 77.6 mm
capacity: 1483 cc
compression: 8.3:1
Horsepower: 77 PS @ 5200 rpm
Torque: 12.0 kg-m @ 3200 rpm
Build Dates
1965 April: 520 introducion
1966 October: 4-eye (4 headlamp) introduction
1968 May: 521 minor change introduction
1969 July: L16 engine introduction for PL521
