If you get new bearings, keep in mind that inexpensive bearings do wear over time. Datsun used triple alloy bearings which do not wear out, but only if the engine loses oil pressure they will be damaged, or if debris gets into the oil.
Measuring Bearing Clearance
It is difficult to tell by visual inspection if bearings are worn. It is normal to have some pattern on them.
Direct measurement: The best way to check is to use plastic thread. Buy the Plastigauge (just a couple of dollars) and put it back together. The amount the thread is squished tells how much actual clearance it has.
Plastigauge see wikipedia article
Indirect measurement: Measure the journals with a precision micrometer, then calculate the clearance.
It is suggested to measure clearance after fitting/refitting bearing shells to confirm actual clearance.
Datsun Factory Service Manual:
Measuring Main Bearing Clearance
Regarding rod bearings, it says "Measure connecting rod bearing clearance in the same manner".
Connecting Rod Bearings
The -25720/-H2310 bearing shell produces the most desirable bearing clearance for racing purposes when applied to a standard size crankshaft. The other shells exist in order to obtain proper clearance when compensating for the variations in the crankshaft or connecting rod journals.
8 each required: * 12111-25720 .0590" * 12111-25721 .0588" * 12111-25722 .0585" * 12111-25723 .0592" * 12111-25724 .0583"
12111-20906 BUSHING-CONNECTING ROD UNDERSIZE 100 12111-20910 BEARING-CONNECTING ROD STD 12111-20900 BEARING-CONNECTING ROD STD 12111-20901 BUSHING-CONNECTING ROD UNDERSIZE 8 12111-20902 BUSHING-CONNECTING ROD UNDERSIZE 12 12111-20903 BUSHING-CONNECTING ROD UNDERSIZE 25 12111-20905 BUSHING-CONNECTING ROD UNDERSIZE 75 12111-20904 BUSHING-CONNECTING ROD UNDERSIZE 50
Main Bearings
Crankshaft bearings
BEARING SET
- 12212-H1000 SET-BEARING US 1.00MM 1 A12 -
- 12207-M7201 SET-BEARING STD 1 A12 - 12207-H1000 $71.58
- 12207-H1000 SET-BEARING STD 1 A12 -
- 12208-H1000 SET-BEARING US 0.20MM 1 A12 -
- 12209-H1000 SET-BEARING US 0.25MM 1 A12 -
- 12210-H1000 SET-BEARING US 0.50MM 1 A12 -
- 12211-H1000 SET-BEARING US 0.75MM 1 A12 -
MAIN BEARING (#1/#5, SHELL THICKNESS)
4 each required
- 12215-H2310 .0720"
- 12215-H2311 .0718"
- 12215-H2312 .0715"
MAIN BEARING (#2/#4, SHELL THICKNESS)
4 each required
- 12231-H2310 .0720"
- 12231-H2311 .0718"
- 12231-12312 .0715"
MAIN BEARING (CENTER, SHELL THICKNESS)
2 required
- 12247-H2310 .0720"
- 12247-H2311 .0718"
- 12247-H2312 .0715"
