Front Suspension Specification
Revision as of 19:56, 24 December 2012; view current revision
Category: Front Axle And Front Suspension
This page is for factory specifications. For modified settings, see Category:Suspension Modifications.
Wheel Alignment
Camber, Caster and Toe-in
See main article: Wheel alignment
Factory Front Suspsension Specifications
Coil Spring Specifications
North America specification
 B110B210B210
with/AC
B310 1980-1982B310 1980-1982
w/AC
B310 1980
w/AC USA
A12A
wire diameter10mm10.5mm10.8mm10.5mm10.8mm10.5mm
coil diameter110mm O.D.
100mm I.D.
100mm100mm 100mm100mm 100mm
Free length338mm ±101977: 375mm
1974: 353mm
1977: 388mm375mm
358mm CAN A12A
366mm USA A12A
381mm USA
375mm CAN
375mm
Effective Turns 6.257.58.25???
Spring constant1.6kg/mm
(89.6 lb/in)
??1.62kg/mm
(90.7 lb/in)
1.65kg/mm
(92.4 lb/in)
1.62kg/mm
(90.7 lb/in)
Effective Turns: Since the coils are closed on each end, they contribute less to the spring rate. The Actual Turns are about 1.5 more than effective turns.
Note that B310 spring is identical to North America B210 spring. The B310 however uses a different upper spring seat.
1974-up B120
B120 pickup:
Coil Spring
  • Wire diameter: 10mm (0.39 in)
  • Coil diameter: 100mm (3.94 in)
  • Loaded (normal load) length: 326mm (12.83 in)
  • Effective turn: 6.2
  • Spring constant: 1.6 kg/mm (90.0 lb/in)
Strut damper
  • Piston Rod diameter: 18mm (0.71 in)
  • Piston diameter: 25mm (0.98 in)
  • Stroke: 164mm (6.46 in)
Damping Force at 0.3m/sec (1.0 ft/sec)
  • Expansion/Rebound: 38-58kg (84-128 lb)
  • Compression: 17-27 kb (37-60 lb)
