The front wheel hub contains the Wheel Bearings. The brake rotor (or brake drum) is bolted to the hub.
drum hub vs. disk hub
click
The brake rotor bolts to the back of the hub
D1 25mm inner bearing journal diameter D2 15mm outer bearing journal diameter
DRUM - ASSY-HUB ROAD WHEEL FRONT
- B110: 40202-18051 DRUM BRAKE
- B210: 40202-18000 DRUM 1974-1975
- B210: 40202-H7405 DRUM 1976-1978 Japan
??? (is this drum or disc hubs?)
- B210: 40202-H7425 DRUM 7510- Van Japan
- B210: 40202-H7425 DRUM 1976-1978 Japan
DISC - ASSY-HUB ROAD WHEEL FRONT
- B110: 40202-H1005 DISC BRAKE
- B210: 40202-H1005 DISC 1974-1975 GX
- B210: 40202-22000 DISC -0775 USA
- PB210: 40202-22050 DISC 1974-1975
- PB210: 40202-A0155 DISC 7510-
- B210: 40202-A0155 DISC 0875- USA
- B210: 40202-A0155 DISC 1976-1978 L16 Japan
- B310: 40202-H7405 DISC, small rotor (Canada A12A)
- B310: 40202-W5050 DISC, large rotor (A14/A15, A12A USA)
Grease Caps
B10, B110 and early B210 uses the smaller size dust cover 40mm?
40234-18000 CAP-HUB FRONT WHEEL
Larger caps 44 mm?
40234-28500 CAP-HUB FRONT WHEEL * B310 (both hub types) * Late B210 (both hub types)
A10 Hub
A10 uses same hub as 710.
1.25" inner bearing journal diameter 0.75" outer bearing journal diameter
