Datsun 1200 takes a traditional spin-on oil filter with 80-82 mm diameter and threads of 3/4-16 (fine thread).
Pretty much any A-series filter fits. Or any with the same threads and diameter. Few are too long for the 1200.
Nissan 15208-H8920 Oil Filter $7.08 * formerly: 15208-H1010 115 height $8.27 USD 0272-7910 ** formerly: 15208-13211/15208-13212 145 length
15208-55Y00 Oil Filter $7.08 USD formerly: * 15208-H8911 FILTER ASSY-OIL 7911-8502 * 15208-H8903 FILTER ASSY-OIL 8502-
Specifications: Threads: 3/4-16-UNF-2B Outside Diameter: 80 Seal diameter: 70mm (original spec) or 63mm (revised spec)
Australia/New Zealand: Ryco Z145A (102mm tall) Ryco Z37 (143mm tall)
http://www.rockauto.com ELEMENT-oil filter, cartridge PRO-TEC 150 $2.43 BECK/ARNLEY 0418723 $4.41 BOSCH 72133 $4.41 WIX 51361 $4.67 ACDELCO PF34 $4.88 FRAM PH3639 $6.00
Tokio FL-208(Y) 1300, 1500 C-201 FRAM ExtraGuard PH3639 Purolator #L30042 Deutsch #D601 Purolator PER42 (DATSUN,TOYOTA) Purolator L30042 Pennzoil PZ8 Champion PH2822,2825 AC PF1026 (?)
Newer A-series filter PN 15208-H8920 (Length: 130) Tokio FL-208 C-208 CKO-1218 SP-842 FC 208 15208H8923 T-3135
Ford F1 Filter
TIP: Use a Ford oil filter #F-1 on your 1200. You only need to use a rotary grinder to grind 1/4 inch off the engine boss. The rotary bit cuts cast iron like butter. Then it fits.
- bigger capacity
- In the US, it is less expensive than the small "import" filter
Other A-series
NISSAN SUNNY,CHERRY (Length: 100) FL-207 15208-H8916 15208-H8911 15208-H8994 SP-929 15208-H8917 15208-H8912 15208-H8905 15208-H8904 15208-H8903 15208-H1011 15208-H1010 Fram ExtraGuard PH3682 Fram ToughGuard TG3682 Fram DoubleGuard DG3682 Fram X2 XG3682 Purolator L24457 Pennzoil PZ27 Champion PH2827,2903 NISSAN,SUBARU AC Delco PF8903 Wix 51361 Champ PH2827
spin-on oil filter used on Nissan 200SX 4 cyl. 1.8L, 2.0L F.1.,& V6 3.0L F.1. engs., 300ZX V6 3.0L eng., M-10 Sedan 4 cyl. 2.0L F.1.eng, Maxima V6 3.0L F.1.eng, Micra 4 cyl, 1.2L eng., Pathfinder V6 3.0L F.1.eng.,Pickups V6 3.0L F.1.eng., Stanza 4 cyl. engs. Van 4 cyl. 2.4L F.1.eng.,Subaru 4 cyl. 1.6L & 1.8L, XT-6 Turbo 6 cyl. 3.0L Turbo. (Replaces: Nissan 15208-H8903; Subaru 15208-AA000) Equivalent: AC: PF1232 CHAMP: PH2827 FRAM: PH3682 MOBIL: MO-4457 MOTORCRAFT: FL-839 NAPA: 1361
B210, B310, F10 Fram ExtraGuard PH46 Purolator L10168 (Audi 5000 Turbo) AC DuraGuard PF34: PF34 #6437982 AC PF34 fits: * 74-82 DATSUN F10,210,B210,310 * 78-80 FORD FIESTA L4-1.6L * 71-73 PINTO L4-1.6L * 72-75 CHEV LUV TRUCK * 83-90 MERCEDES-BENZ 4 CYL * 70-79 SUBARU * 86-90 TOYOTA VAN 2.2L, 69-80 W/KC, RC ENGINES * 81-84 STARLET * 84-85 TERCEL L4-2.0L
