Here is a list of 1/4 miles times from the varied list of Datsuns in our club. (Main Source)
A12
Fat_120y
- 60 foot time:2.428
- 1/4 mile time:16.093
- MPH/KPH:89.4mph
- CAR:120y 2dr sedan
- MOTOR:1200
- GEAR BOX:standard 4 spd
- CLUTCH:exedy HD organic
- DIFF:standard pull out centre
- TURBO/SUPER CHARGER/CARBY:32/36 weber, with td04l baby turbo 10psi
EXHAST:3"
- WHEEL/TYRE package:12" 165/65/12
boofhead
- 60 foot time: 2.593
- 1/4 mile time: 17.623
- MPH/KPH: 78.07mph
Calder Park, Victoria, 25/03/2006
- CAR: 1973 1200 sedan
- MOTOR: A12 GX'ish mock up
- GEAR BOX: 60a 5spd
- CLUTCH: excedy organic
- DIFF: stock h145
- TURBO/SUPER CHARGER/CARBY: twin 40mm webers
- EXHAST: 4-1 extractors, 2" system, single muffler
- WHEEL/TYRE package: 15x6" skyline ti alloys, 195/50/15 street tyres
littledarkone
- 60 foot time: 2.592
- 1/4 mile time: 19.316
- MPH: 68.80
- Car: 75' 120y 4 Door Sedan
- Motor: A12 Standard
- Gearbox: 56A 4 sp
- Clutch: Standard
- Turbo/Super Carger/ Carby: 32\36 DGV
- Exhaust: A15 manifold with 1 3\4 inch pipe into lukey semi baffled dumped at diff
- Wheel/ Tyre package: 175\70 R13 Front 155\something or rather 12 Rear
Burke_a_lot
- 60 foot time:
- 1/4 mile time: 23.0
- MPH/KPH:
- CAR: datsun 120y coupe
- MOTOR: A12
- GEAR BOX: stock
- CLUTCH: stock
- DIFF: stock
- TURBO/SUPER CHARGER/CARBY: home made turbonator, force fuel injection
- EXHAST: none
- WHEEL/TYRE package: 12"
A14
finn
- 60 foot time:1.88
- 1/4 mile time:12.1
- KPH:187
- CAR:Datsun 1200 coupe
- MOTOR:A14
- GEAR BOX:Ford type 9
- CLUTCH:190mm
- DIFF:Escort rs2000
- TURBO/SUPER CHARGER/CARBY:Turbo garret kkk k25, megasquirt injection, 2bar boost
- EXHAST:3"
- WHEEL/TYRE package:R14-205 street slicks(dot)
minnesh
- 60 foot time:
- 1/4 mile time:13.8
- KPH:
- Car :Sedan Datsun 1200
- Motor: a14
- Gearbox : Toyota 3t
- Clutch : copper
- Diff : Alfa LS
- Carbs : 40 Webbers
- Exhaust : 55mm
- Wheels : 13" cosmo with semis
HYP014
- 60 FOOT TIME : 2.0
- 1/4 MILE TIME : 14.1
- MPH: 97.1
- CAR: 1200 coupe
- MOTOR: A14
- GEARBOX: option1 5speed
- CLUTCH: exeedy ceramic button
- DIFF: h165 locked 3.9:1
- INDUCTION: 45mm throttle bodys
- EXHAST: JTS extractors, 2.5" pipe
- WHEEL/TYRE: 195,50,15 yokohama advans
sparkyZA
- 60foot time:
- 1/4mile time:15.63
- mph/kph:136.4kph
- CAR:1200 gx 4 door
- MOTOR:A14
- CARB:Twin 40 webers
- GEARBOX:4speed std.
- CLUTCH:custom
- DIFF:alfa ls
- EXHAUST:2.25"
- WHEEL/TYRE package:front 155/80/12 rear 185/60/14(semi slicks)
- 1/4MILE TIME 18.59(Wet Track)
- CAR:Nissan Bakkie
- Motor:A14
- GEARBOX:Std 5 speed
- CLUCTH:Stock
- DIFF:Stock
- CARBY:38 weber
- EXT:5oMM
- TIRE/WHEEL package:155/80/12
- STD Steel Rims
A15
datsonovic
- 60 FOOT: ?
- 1/4 MILE: 12.7 SEC
- MPH/KPH: 102 MPH?
- CAR: VB10 1000 wagon
- MOTOR: A15
- GEARBOX: FORD 4 SPEED
- CLUTCH: SOLID SAW BLADE PLATE DUEL DIAPHRAM
- DIFF: 3.89:1 120y BW LOCKED
- TURBO: GARRET TO3 (HIGH FLOW BASED ON RB30)
- EXHAUST: 2.5 INCH DUMPED AT DIFF
- WHEEL/TYRE: 13/7 REBELS 205/65
sticks
- 60 FT: 2.2
- 1/4 MILE TIME 14.4
- MPH 93
- CAR: 1200 ute
- MOTOR: A 15
- G/BOX: 60 series 4 speed
- CLUTCH: L series
- DIFF: H 165
- INDUCTION: 2x45 DCOE Weber
- EXH: extractors 2" system
- WHEEL?TYRE: 13x4.5 Sunny rims 165 kumho,s
A14force
- 60 foot: 2.417
- 1/4 mile:14.6
- MPH: 92.4
- CAR: 1200 sedan
- MOTOR: A15 (Bored to 1526cc's)
- Induction: S/C 14 32/36 weber drawthrough running 7psi
- GEAR BOX: dogleg 60 5spd
- CLUTCH: Standard LD20.
- DIFF: H150 spring loaded locker.
- EXHAST: 2" with two resonators only
- WHEEL/TYRE: 13x6 tridents, with cheap nasty 205/60/13's
3Rotor
- 60 foot:
- 1/4 mile:14.7
- MPH: 100.8mph
- CAR: Nissan 1400 Ute
- MOTOR: A15 (Langley Pistons)
- GEAR BOX: W58 (Supra) was std 4spd
- CLUTCH: 4 puk button, std flywheel\P-Plate.
- DIFF: Std.
- TURBO: GT1749.
- INTERCOOLER: Yes, custom.
- EXHAUST: 2.5 SS, one box.
- WHEEL/TYRE Front: 195/50/14 Michelin.
- WHEEL/TYRE Rear: 175/80/14 Goodyear.
SOURCE: G-Tech.
DATE: 31mar07 11:54:00 aprox.
Grunterhunter
- 60foot time: 2.1
- 1/4mile time:14.72
- mph/kph:144 kph
- CAR:1200 ute
- MOTOR: A15 (104rwhp @ 4800rpm)
- CARB: 32/36 weber
- SUPERCHARGER: Toyoya SC14 Rootes Blower, 10psi
- CLUTCH: sunny
- DIFF: H165 4.11
- EXHAUST:2.5"
- WHEEL/TYRE package:front 185/60/14 rear 185/60/14
Grunterhunter
- 60 foot time: 2.3
- 1/4 mile time: 16.9
- MPH/KPH: 76mph (into 8kt headwind)
- CAR: 1200 ute
- MOTOR: A15, mild cam (54rwkw)
- GEAR BOX: 5 speed
- CLUTCH: stocka
- DIFF: 4.11
- TURBO/SUPER CHARGER/CARBY: 32/36 DGV weber
- EXHAST: Extractors into a straight through 2.5"
- WHEEL/TYRE package: 185/60R14
datsa73
- 60 foot time: I'll have to check
- 1/4 mile time: 17 sec
- MPH/KPH: Speedo's gauge is off
- CAR: 1973 2 Door Sedan
- MOTOR: A15 Bored-Balanced-Port Polished- Redline at 9K
- GEAR BOX: B210 5 Speed
- CLUTCH: Standard
- DIFF: 1200
- TURBO/SUPER CHARGER/CARBY: Dual 32/36 Downdrafts
- EXHAST: 2 1/2" with Glasspak
- WHEEL/TYRE package: 15" 280z wheels
L20B
sticks
- 60FT: 1.85
- 1/4 MILE: 13.1 @ 100mph
- CAR: 1200 sedan
- MOTOR: L20b
- GEARBOX: 1600 datsun
- CLUTCH: upgraded L20b
- DIFF: H165
- INDUCTION: 2x45 DCOE weber
- EXHAUST: extractors 2.5 system
- WHEEL/TYRE: 13x6 steel 185 advan's (second hand)
sikdatto1200
- 60 foot time: 2.1
- 1/4 mile time: 16.7
- MPH/KPH: 79mph
- CAR:Datsun 1200 sedan
- MOTOR:Standard L20b with ported head,(engines compression not healthy)
- GEARBOX:280zx 5spd
- CLUTCH:Standard 280xz
- DIFF:Borgwarner 3.9, locked
- TURBO/SUPER CHARGER/CARBY:38adm webber and adapter on standard manifold
- EXHAUST:2 inch, standard manifold
- WHEEL/TYRE PACKAGE:14inch et turbo rims on the front, 13inch 175 rears
CA18DET
jonboy
- 60 foot time:1.64
- 1/4 mile time:11.54
- MPH/KPH:118mph
- CAR:1200 ute
- MOTOR:standard internal ca18det
- GEAR BOX:r30
- CLUTCH:extreme
- DIFF:r31 4.11
- TURBO/SUPER CHARGER/CARBY:gt25 75hp nos
- EXHAST:3inch
- WHEEL/TYRE package:m@h 26x6 slicks
ca18det_man
- 60 foot time: 1.74
- 1/4 mile time: 12.0
- MPH/KPH:113mph
This 1/4 mile time was around 7 years ago when I first built it. It was regoed and fully legal driven too and from the track (old eastern creek wed night street meet)
- CAR: 1200 coupe
- MOTOR:Ca18det
- GEAR BOX: MR30 skyline (stumpy)
- CLUTCH:Daiken brass button sprung center
- DIFF:Mitsibishi scorpoin 4.6:1
- TURBO: GT25 290hp model
- EXHAST:3" to diff then 2.5"
- WHEEL/TYRE package: 14x6 with 205/60/14 hankooks
12OOU
- 60 foot time: 1.71
- 1/4 mile time: 12.4
- MPH/KPH: 116mph
- CAR: Datto 1200 Ute
- MOTOR: CA18DET
- GEAR BOX: CA18 5 speed
- CLUTCH: 3400lbs 5 puk button
- DIFF: r31
- TURBO/SUPER CHARGER/CARBY: to4e
- EXHAST: 3"
- WHEEL/TYRE package: 225/50 toyo proxies
LAGWAGON
- 60 foot time:
- 1/4 mile time: 12.6
- MPH/KPH: 108mph
- CAR: Datsun 1200 Wagon
- MOTOR: CA18 det
- CLUTCH: Extreme cushion button
- DIFF: Hilux with 30 spline axles
- TURBO/SUPER CHARGER/CARBY: S15bb factory jap spec
- EXHAST: 3 inch dump only
- WHEEL/TYRE package: 13in x 8in M/T drag slicks
matty
- 60 foot time: 1.815
- 1/4 mile time: 12.753
- MPH/KPH: 109.04mph
- CAR: 1200 Ute
- MOTOR: CA18DET
- GEAR BOX: CA18DET 5 speed
- CLUTCH: Jim Berry 2125lbs
- DIFF: r31 LSD
- TURBO/SUPER CHARGER/CARBY: GTi-R T28
- EXHAUST: 3"
- WHEEL/TYRE package: 195/60R14 Azenis
short-coupe
- 60 foot time: 2.111
- 1/4 mile time: 12.835
- MPH/KPH: 109.14mph (175.65)
- CAR: 1200 coupe
- MOTOR: ca18det
- GEAR BOX: s13 5sp.
- CLUTCH: 5puck
- DIFF: r31 4.11 lsd
- TURBO/SUPER CHARGER/CARBY: t25g
- EXHAST: 3"
- WHEEL/TYRE package: 205/50/15" s-drive yoko's
kegs
- 60 foot time:
- 1/4 mile time:13.6
- MPH/KPH:106mph
- CAR:1200 ute
- MOTOR:ca18debt haha debt
- GEAR BOX:mr30 stumpy
- CLUTCH:exedy
- DIFF:8 3/4 inch skyline r31
- TURBO/SUPER CHARGER/CARBY:t25
- EXHAST:3 inch
- WHEEL/TYRE package:stockies
oan878
- 60 foot time: 1.918
- 1/4 mile time: 13.626
- MPH/KPH: 95.85/154.25
- CAR: Datsun 1200 sedan 4 dr
- MOTOR: CA18 det
- GEAR BOX: CA20 5 speed
- CLUTCH: excedy soild centre brass button
- DIFF: locked h165
- TURBO/SUPER CHARGER/CARBY: stock turbo
- WHEEL/TYRE package: 15in 215/60 toyo proxies
FRKYCA
- 60 foot time:
- 1/4 mile time: 13.9
- MPH/KPH:
- CAR: 1200 sedan 71
- MOTOR: ca18det
- GEAR BOX: 3 speed auto
- CLUTCH:
- COMPUTER: standed
- DIFF: ute 1200 diff
- TURBO/SUPER CHARGER/CARBY: t25 standed
- EXHAST: 2.5"
- WHEEL/TYRE package: standed 14"bluebird (white walled )
mcgee
- 60FT: 2.071
- 1/4MILE: 14.36
- MPH/KPH 94.8MPH
- CAR: 1200 coupe
- MOTOR: CA18DET
- G/BOX: manual CA18
- DIFF: Mitsubishi 3.9 LSD
- TURBO: garret GT2540R (10psi)
- EXHAUST: 3"
- WHEEL/TYRE: 195/60R14
dattodude
- 60 FOOT TIME : dunno
- 1/4 MILE TIME : 15.0
- MPH: 91mph
- CAR: 1200 sedan (my old car)
- MOTOR: CA18det (<100psi in one cylinder) 78kW@wheels
- GEARBOX: Stumpy Skyline 5 speed (crunched every gear change)
- CLUTCH: whatever
- DIFF: h165 3.9:1
- INDUCTION: EFI, S14 T28
- EXHAUST: 2.25 mandrel.
- WHEEL/TYRE: 205/14-60
SR20DET
sticks
- 60FT: 1.42-slick, 1.39-radial
- 1/2 track: 113mph 112mph
- 1/4MILE: 9.70 @ 137.07 slick, 9.79 @ 135.98 radial
- CAR: 1200 wagon
- MOTOR: sr20det
- G/BOX: trimatic (transbrake) 5200 convertor
- DIFF: hilux 3.7ratio
- TURBO: garret gt30/40 (30 psi pump fuel) nos
- EXHAUST: 3" with plumbed back gate pipe
- WHEEL/TYRE: mt drag, 26-8.5-15 8' cragar star
mt drag radial, 235-50-15 7" ford pursuit rim
1200post
- 60 Foota: 1.467
- 1/4 mile: 11.012
- MPH/KPH:121.50/195.53
- Car:Datsun 1200 post 2 door sedan
- Motor:SR20de stock
- Gearbox: series 3 bluebird
- Cluch: PBR standard
- Diff: Galint
- Turbo:T03 of a Z18t
- Exhast: 2 1/2 mandrel bent mild steel
Built By: Myself and my very understanding girlfriend
Evey
- 60 foot time: 2.2
- 1/4 mile time: 12.9
- MPH/KPH: 116mph
- CAR: Datsun 1200 Ute (MIN712)
- MOTOR: SR20DET
- GEAR BOX: 5 SPD SR
- CLUTCH: Extreme Button
- DIFF: H165
- TURBO/SUPER CHARGER/CARBY: T28 Plain B
- EXHAST: 3 inch mandrel
- WHEEL/TYRE package:205.40.16Falken Ziex street tyres
Z18T
trb012
- 60ft time:2.137
- 1/4 mile:14.56
- MPH:94.81
- CAR:120 y sedan
- MOTOR:Z18 turbo
- GEARBOX:Z18 5 speed
- DIFF:VN borg warner 4.11 lsd
- INDUCTION:Gas research 450cmf carby
- TURBO:t3/t4 hiflow
- EXHAUST:2-1/2 inch mandrel
- WHEELS/TYRES:15/7 superlites with goodyear 195/55/15 f1's
SR20DE
twincharged
- 1/4 mile time: 14.65
- MPH/KPH: 93.10 mile
- CAR: Datsun 1200 coupe
- MOTOR: SR20DE STANDED Staight out of the half cut
- GEAR BOX: Standed siliva 5 speed
- CLUTCH: Det clutch
- DIFF: 4.3 lsd 120y diff
- TURBO/SUPER CHARGER/CARBY: EFI N/A
- EXHAST: 2.5 inch
- WHEEL/TYRE package: 195x15x6.5 es100
Other 4 cylinder
JVML
- 60 foot time:1.276
- 1/4 mile time: 9.8s
- MPH/KPH: 132mph/211.2kph
- CAR: Datsun B110
- MOTOR: 4AG Turbo...Dyno 460HP at wheel
- ECU: Microtech
- Turbo Boost: 45psig, at 3rd Gear, RPM 12,128
- Injector:750cc
- GEAR BOX: 2JZ Toyota Supra
- FLYWHEEL: 3.6Kg JAM
- CLUTCH: 6 points HKS
- DIFF: 4.3 AE86 LSD Full Time
- TURBO/SUPER CHARGER/CARBY: Garrett TO4E
- EXHAST: 3"
- WHEEL/TYRE package: 215x15x65 Fully Slick Hoosier
AOO00A
- 60 foot time: 2.227
- 1/4 mile time: 14.803
- MPH/KPH: 92.40mph (148.71kph)
- CAR: 1200 ute
- MOTOR: 4AGZE
- GEAR BOX: Toyota Sprinter
- CLUTCH: Made
- DIFF: LC Lancer open centre
- TURBO/SUPER CHARGER/CARBY:Supercharger STD 4AGZE
- EXHAST: 2.5"
- WHEEL/TYRE package: 205/50/15" Falken Rear
Tyrie
- 60foot time:
- 1/4mile time:15.4
- mph/kph:140.0kph
- CAR:120Y sedan 1060kg
- MOTOR:4agze
- CARB: no
- GEARBOX: T50 5speed
- CLUTCH: Excedy 4puck with very little clamping pressure :(
- DIFF:R31 3.9 LSD
- EXHAUST:2.5" with one muffler
- WHEEL/TYRE package:front 195/50R15 rear 7x22x13 AVON formula ford tyres (rooted)
Only a Gtech run as we arent privilaged enough to have a track here.
Rotary 12A
ANGE
- 60 foot time: 2.2
- 1/4 mile time: 15.5
- MPH/KPH: 85mph
- MOTOR: 12a rotary (standard)
- GEAR BOX: Ser4 Rx7 5spd
- CLUTCH: standard
- DIFF: 4.3 lsd
- TURBO/SUPER CHARGER/CARBY: nikki 4brl
- EXHAST: 2.25"
- WHEEL/TYRE package: 15x6 195/55 semi slick
V8
dat383
- 60ft time:1.3
- 1/4 mile:9.89
- mph:133.5mph
- CAR:1200 sedan
- MOTOR:383 small block chev
- GEARBOX:powerglide
- DIFF:9 inch spool
- INDUCTION:aspirated,1050 methanol carby
- EXHAUST:custom,3 inch,gonzo mufflers.
- WHEELS/TYRES:15x10 &15x3 weld pro stars.26x10inch slicks.
Electric
EVdude
- 60 foot time: 1.59
- 1/4 mile time: 12.1
- MPH/KPH: 107 mph
- CAR: '72 Datsun 1200 sedan
- MOTOR: Siamese 8 dual Armature
- GEAR BOX: none, direct drive
- CLUTCH: none
- DIFF: Ford 9 inch w/Detroit Locker & 31 spline axles
- TURBO/SUPER CHARGER/CARBY: none
- EXHUAST: none
- WHEEL/TYRE package: front 13 x 5.5 with 175/60 Nitto rear 14 x 6 with 215/60/14 BF Goodrich G Force drag radials
