Engine Room Harness assembly
* 24012-H1002 -7103
* 24012-H1004 -7103 OPTION
* 24012-H1206 7205-7204 [catalog appears to have a mistake]
* 24012-H1205 7205-7302 [catalog appears to have a mistake]
some note about the old Coil connector
* 24012-G1400
* 24012-G1401 7303- > 24012-G1400
* 24012-G1604 7510-8012
* 24012-G1605 8101-8109
* 24012-G1900 8110-8503
* 24012-G1901 8504-8608
* 24012-G1902 8608-8910
* 24012-95W00 8910-
- 24013-95W00 HARNESS ASSY-INSTRUMENT 8910-
- 24014-95W00 HARNESS ASSY-BODY 8910-
- 24015-95W00 HARNESS ASSY-TAIL SB 8910-
- 24015-95W01 HARNESS ASSY-TAIL LB 8910-
Engine Room Sub-harness assembly
* 24077-G1600 7510-8910
* 24077-95W00 HARNESS ASSY-ENGINE ROOM SUB 8910-
Room Lamp harness assembly
* 24160-G1000 HARNESS ASSY-ROOM LAMP all early
* 24160-G1001 HARNESS ASSY-ROOM LAMP 7510-
- 24022-01E01 LINK-FUSIBLE 8910-
- 24310-95W00 BLOCK ASSY-FUSE 8910-
- 24311-92W00 COVER-FUSE BOX 8910-
Instrument Panel
- 25160-H1101 SWITCH ASSY-LIGHTING all
- B5160-B6800 replaced the above $41.08 USD
- 25230-C9970 RELAY NILES ENGINE CONTROL 8910-
- 25230-C9980 RELAY MIYAMOTO ENGINE CONTROL 8910- $28.42 USD
- a 4-pin relay with a blue plastic housing in either Niles brand (25230-C9970) or Miyamoto brand (25230-C9980). Either of the two brands is interchangeable
- Used in many 1979-1997 Nissans
- 26320-89905 RELAY ASSY-PASSING LIGHT $13.45 [also used for horn relay]
- 25260-G1060 SWITCH ASSY-WIPER 8110-
- also 7804-8109 w/INTMT WIPER
- 28890-B8060 AMP-INTERMITTENT WIPER
Engine Control
- 22604-95W00 ENGINE CONTROL MODULE 8910-
- 22690-F5300 HEATED OXYGEN SENSOR, REAR 8910-
- replaced by 22690-17B00 $167.92 USD
Fuel
- 22360-01M00 SWITCH ASSY-VACUUM 8910- $80.50 USD
