Hitachi DFC306 is an electrically controlled feedback carburetor, used on A12 engine for Sunny Truck beginning October 1989.
Model: DFC306-26 Air horn entrance (inside diameter - outside diameter) 54-59 mm Primary nozzle system (primary) secondary side (secondary) Zenith Stromberg protruding type Throttle Bore (mm) 26/30 Venturi (mm) 23/27 Venturi in diameter (inner - outer diameter) (mm) - 13-16 Venturi small diameter (inner - outer diameter) (mm) 8-16 7-10 Nozzle diameter (inner diameter - outside diameter) (mm) 2.1-3.0 2.8-4.0 92 main jet size 120 (# engraved) Diameter 43 80 slow jet (# engraved) Economizer diameter bleed 95 140 (# engraved) 90 main jet diameter correction (# engraved) - Slow diameter air bleed correction for 230 (# engraved) - Main air bleed size 70 60 (# engraved) 155 slow air bleed size 80 (# engraved) All 閉角 degree throttle valve 9 20 (degrees) Float chamber fuel pressure (kg/cm2) 0.24 Float level standard (from the top of the float chamber) (mm) 21 Idle port (mm) 1.6 Opening fast idle (dimension G) 1.35 (0.84) (degrees) Auto choke choke system Two-stage diaphragm complete explosion 爆開 complete degree automatic choke at low temperatures * (dimension R) 25 (1.66) (degrees) At high temperatures 33 (2.48) (degrees) Choke set temperature (℃) 16
Vanette
C22 Vanette used a feedback carburetor.
