B210 Engine Swaps
Revision as of 02:08, 24 July 2015; view current revision
Category: Datsun B210
B210s can swap in all the same engines as B110 (see Engine Swaps).
But there are a few differences, including:
  • Later B210s have H150 (stronger) diff, nearly identical to B110 diff, but stronger
  • Fuel Tank#return line
  • Wider engine crossmember than B110
North America
B210s for North America all came with tall-block engines (A13 and A14). They use the Datsun 510/610 suspension and engine mounting points.
  • 510/610 LCAs
  • 610 anti-swaybar
  • 610 tension rods
  • 610 modified struts and brakes
  • 510 crossmember modified from the factory with A-series engine mount horns, requiring a mid-sump oil pan (510 style)
