2-inch Strut Inserts
Revision as of 02:00, 15 November 2015; view current revision
Categories: Front Axle And Front Suspension | Suspension Modifications
HB210 and most Datsuns other than B110 use a 2.0 inch (50.8 mm) strut size. This article will help you choose parts for rebuild or replacement. For 1200 struts, see 45 mm Strut Inserts.
2" OD Strut Inserts
Most Datsun struts use 2 inch (50.8mm) diameter strut tubes. The insert itself will usually be 1-5/8 inch (41.3mm) diameter and thus too big for 45 mm struts, although some are 1.5" (38mm) and so will also fit in 45 mm Struts.
Nissan
  • 56105-N8425 B210
    • superceded 56105-H5925
    • B210 with A14
    • B210 with A12 1977-1978
Aftermarket
  • Monroe Sensa-Trac 73949 $35
    • Compressed Length: 17.875"
    • Extended Length: 24.250"
    • Body Length: 17.375"
    • Travel: 6.375"
  • AC/Delco gas-charged 50335/88945515 $39
  • KYB 364003 GR-2 gas $52
    • 1974-1978 B210
    • 1979-1982 210
    • 1980-1983 200SX
    • 1978-1981 510
  • AutoTek 181 00-167
KONI
  • From the 1984 Nissan Competition Catalog
    • 99996-1912R B210/FRONT KONI SHOCK ABSORBER
      • KONI 86-1912
    • B310 Nissan 99996-2002P 210/FRONT KONI SHOCK ABSORBER
      • KONI 86-2002
    • B310 Nissan 99996-2002T 210/FRONT (SPORT) KONI SHOCK ABSORBER
      • KONI 86-2002
Inserts
356 Body length
1978-1983 280zx TURBO/NON TURBO
364 Body length/ 555 Extended/ 318 Collapsed, Book reference wrong???
R31 6/86-12/90, Pintara
Gabriel G44946/G44972
Koni Red Specials - 86-2361
362 body length/ 559 extended/ 392 collapsed
Z31 (300ZX) 5/84-85
Gabriel - G44936
357 body length/ 531 extended/ 366 collapsed
Z31 (300ZX) 1/86-89
Gabriel - G44968
Tokico Performance Gas - HZ3100
381 Body Length/ 543 Extended/ 398 Collapsed
240/260/280z (S30),Gazelle
from chassis#30-060001 strut tube size is increased inside and outside, some inserts will fit both but leading manufacturers are model specific.
non model specific
Mulholland - 2351501
Gabriel - G44869
Monroe US Made - 86361
up to chassis#30-060000
Koni Red Specials - 86-1811
Tokico HP Series - HZ3015
KYB GR2 Gas - 361002
Tokico Illumina 5-Way Adjustable - BZ3015
Tokico HP Series - HZ3012
KYB GR2 Gas - 361003
Tokico Illumina 5-Way Adjustable - BZ3012
403 Body length/ 575 Extended/ 415 Collapsed
200b (810 L24E) 10/77-81, 240K (C110) 73-79, Skyline C210 3/78-80, R30 3/81-86, 200SX 77-79, 1600 (P510) 8/71-73
Gabriel - G44856/G44900
Vera - 62-00976
Koni Red Specials - 86-2224
410mm (415mm if including gland nut) 340mm travel
1600 (P510) 68-8/69, 180b (P610) 72-77
Monroe - MC962,
Gabriel - G44864
437mm Body Length
Stanza/Violet (H510) 77-81, Sunny (B310) 78-81, 200SX 80-83
Monroe - MC949,
Gabriel - G44752
Vera - 62-00570
KYB GR2 Gas - 364003
??????? Not sized yet
1600 (P510) 9/69-7/71
Monroe - MC926
Gabriel - G44865
280ZX (S130) 78-83, Bluebird 80-83, Maxima (910) 82-84
Tokico Illumina - BZ3038,
Tokico Illumina 5-Way Adjustable - TOBZ3038
Tokico Performance Gas - HZ3038
Gabriel - G44977
KYB GR2 Gas - 365013
GM Holden Commodore
You can use Commodore inserts (VB to VP) which are a little tight and 1/2 inch shorter.
Monroe 25-3632
* Commodore    1978-1993 VB,VC,VH,VK,VL,VN,VP
* Caprice      1990-1994 VQ including Statesman
* Toyota Lexen 1989-1993
* Type T6
* Body length:      405  mm (13 mm shorter than stock)
* Length Extended:  599  mm
* Length Compressed:405  mm
* Greater stroke than 1200 shocks
* Body Diameter: 44.5 mm ?
* Nut 110-039-037
* Ring 137-A61-007
