Carpet Cleaning Machine
Revision as of 06:15, 18 January 2016; view current revision
Category: A-series Engines
Prochem Performer 405 truckmount
http://www.youtube.com/watch?v=jdyLKlyDV30
A15 Industrial Engine
carbureted
65 hp
OR A12 Industrial Nissan Engine 32hp
A15
governer $1009
2002 PowerVac II (48hp)
2002 Performer (48hp)
2002 Performer 405 (48hp)
Everest truckmount
A15
Zenith EFI fuel injection (ZEEMS)
2002 Nissan A15 with CAL emissions
post
Zenith Fuel Injection
post
post
Zenith ECU
post
post
Zenith Power Products
http://zenithpp.com/engines_a15.htm
Intermittent output (SAE Gross J1349) 46 HP/3,600 rpm
Continuous output (SAE Gross J1349) 39 HP/3,600 rpm
Peak torque (SAE Gross J1349) 11 kg-m (80 ft-lb)/2,200 rpm
Minimum fuel consumption 225g/Hp-hr (0.496 lb/HP-hr)/3,200 rpm
Fuel and type Gasoline, 4-cycle, O.H.V.
Cylinder arrangement 4 in-line
Combustion chamber Wedge shape
Bore x stroke 76mm x 82mm (2.99 x 3.23 in)
Total piston displacement 1,487 cc (90.74 cu in)
Compression ratio 9.0 : 1
Length x width x height (standard model)
  527.8 x 530.8 x 576.3mm (20.78 x 20.90 x 22.69 in)
Dry weight (standard model)* 103kg (227 lb)
