Download: Datsun 1200 Competition Suspension Manual
Foreward
Front Suspension
Front Camber Adjustment
See main article: Camber
Adjustable Ride Height
Modified Strut Caliper Mount
Front Hub
240-Z Caliper Modification
Front Springs
Lower Link and Steering Gear
The complete lower suspension link can be left stock. The inner chassis mount rubber bushing may also be left stock since it is very rigid and deflects a minimal amount while cornering.
The complete steering linkage assembly is adequate for competition purposes. This includes the steering gear box, tie rods, tie rod ends, all steering arms, idler arm assembly and the lower ball joint.
Tension Rod and Bushing Modification
Page 11
Sway Bar Assembly
Front Competition Suspension Assembly
Sway Bar Installation
Sway Bar Adjustment
page 20 (blank page)
Rear Suspension Modifications
Rear Spring Modification
Front Spring Eye Bushing
Shocks and Reworks Lower Mount
Rear Traction Bar Mount
Front Spring Hanger Mount Chassis Bushing
Front Spring Hanger Assembly
Traction Arm Assembly
Rear Shackle
Rear Sway Bar Assembly
Rear Competition Suspension Assembly
Final Adjustments
General Handling
page 37
