Template:Diff Terminology
Revision as of 01:02, 15 May 2016; view current revision
Differential: The word "diff" refers to the small gears in the rear end that control the left-to-right wheel speeds
38100 SET-HYPOID GEAR & PINION
open type with differential gears visible
Datsun 1200 uses H145 type differential
By popular usage "diff" is also used to refer to these parts:
  • the Gear Carrier Assembly (pumpkin or "center section" or "diff head"), including Ring and Pinion and the carrier these bolt to
  • or, the entire Rear Axle assembly including the housing, gears, axles etc.
Gear Carrier aka "center" (not to be confused with "center section")
Ring and Pinion (R&P) are the large final-drive gears e.g. the "ratio" gears. Known as "Crown Wheel and Pinion" (CWP) in British English.
Spider gears: The smaller side gears are known as the "spider gears". These are the ones that actually allow a differential speed.
38423 GEAR-SIDE
38427 SHAFT-PINION
38425 GEAR-PINION
LSD: Limited-slip differential. Most designs use a spring-loaded clutch to prevent one wheel from spinning by itself. Instead, the LSD resists spinning but when traction is overcome, both wheels will spin.
