A Dropping Resistor pack is used to lower the current used by the Fuel Injectors. It is one unit with four resistors inside.
A14E
A14 EGI fuel injected engine
22698-N4202 RESISTOR-DROPPING -0780 $60.65 USD 22698-W1401 RESISTOR-DROPPING 0880- <>22698-W1411 <5> 22698-D0300 01451-00171 SCREW (2)
Spec 10 watt 7 ohms (6.8 ohm nominal) N4202 8-wire connector
22698-N4202 is used by: * EUROPE S130 280ZX L28E engine S110 Silvia L18E * USA S130 280ZX L28E engine S110 200SX Z20E * JAPAN B310 A14E 250 Y44E V8 Nissan S110 Silvia Z18E+Z20E Isuzu Trooper 2.6 4ZE1
A15E
A15 EGI engine
22698-W1401 <> 22698-D0300 * B310 A15E * K10.3HB.T,910.(Z18E#+Z20E),B11.(E15E+E15ET),N12.E15T,R30.(Z20E+FJ20E),S110.(Z18E+Z20E+FJ20)
W1401 4-resistor pack???
22698-W1401 source: * USA Pulsar NX 1983-1985 E15T S110 200SX Z20E USA N12 Pulsar E15ET USA * EUROPE 910 Bluebird Z20E N12 Cherry E15ET * JAPAN K10.3HB.T 910 Bluebird (Z18E#+Z20E) B11 Sunny E15E+E15E N12 Pulsar E15T R30 Skyline (Z20E+FJ20E) S110 Silvia/Gazelle (Z18E+Z20E+FJ20)
JECS
22698 RESISTOR-DROPPING
JECS A15-000J01 JECS A15-000G02 * 2-wire * fuel pump resistor JECS A15-000A00 2-wire * 1990 KGN13 GA16I JECS A15-000850 3-wire? * KEN13 CA16DE
22698-36F00 (JECS A15-000G01) * S13(S20DE+SR20DET+CA18DE+CA18DET) * 6-pin squircle connector (pin 5 missing)
22698-N4202 (JECS A15-000571) $60.65 USD * B310.A14E, 250.Y44E, S110.(Z18E+Z20E)
