Bumper Parts
Revision as of 20:21, 19 July 2016; view current revision
Category: Body
Bumpers are the same for USA and Japan markets, except for 1973 USA model bumper.
* 1970 bumpers use small 8mm bolts
* 1970 North America intro with Overriders
* 1973 North America change to safety bumpers
* 1975 change of stays to use large 12mm bolts
Also see: Trunk & Bumper Part Numbers
NOTE: 1973 parts fit older brackets, but older bumper doesn't fit newer brackets.
Front Bumper (Coupe & Sedan)
* 62651-H7000 ASSY-BUMPER,FRONT Sedan, Coupe from 0772 $178
* 62651-H1000, H1001, H1900 ASSY-BUMPER,FRONT Sedan, Coupe
Rear Bumper, sedan
* 85011-H7000 BUMPER-REAR CENTER Sedan from 0772
* 85011-H1900 BUMPER-REAR CENTER Sedan
* 85012-H1000 BUMPER-REAR RH Coupe, Sedan
* 85013-H1000 BUMPER-REAR LH Coupe, Sedan
Rear Bumper, Coupe
* 85011-H7100 BUMPER-REAR CENTER Coupe from 0772
* 85011-H1905 BUMPER-REAR CENTER Coupe
Rear Overriders
85020-H1900 OVERRIDER-REAR BUMPER RH
85021-H1900 OVERRIDER-REAR BUMPER LH
85020-H7000 OVERRIDER-REAR BUMPER RH 1973
85021-H7000 OVERRIDER-REAR BUMPER LH 1973
Front Overriders
62674-H1900 OVERRIDER-FRONT BUMPER RH
62675-H1900 OVERRIDER-FRONT BUMPER LH
62674-H7000 OVERRIDER-FRONT BUMPER RH 1973
62675-H7000 OVERRIDER-FRONT BUMPER LH 1973
85024-H1900 RUBBER-OVERRIDER (4)
NOTE: PB110 front bumper is unique, but PB110 rear bumper is same as B110.
Front Bumper
  • 62651-H1000 ASSY-BUMPER,FRONT [sedan/coupe/van]
  • 62651-H1001 ASSY-BUMPER,FRONT from 0870 (interchanges with former)
    • Two-piece welded vs Three-piece welded
Rear Bumper
NOTE: Japan models had no overriders
  • 85011-H1800 BUMPER-REAR CENTER Coupe
  • 85011-H1400 BUMPER-REAR CENTER Van
  • 85011-H1000 BUMPER-REAR CENTER Sedan
  • 15 85012-H1000 BUMPER-REAR [end cap] RH
  • 16 85013-H1000 BUMPER-REAR [end cap] LH
Japan Sunny Truck
Front
  • Assembly Early
  • 62651-G1001 BUMPER ASS'Y-front STD -7509
  • 62651-H1025 BUMPER ASS'Y-front DX -7509
  • 62651-H1025 ASSY-BUMPER,FRONT Truck 7510-7803 [car-type]
  • Assembly Late - rubber ends
  • 62650-G1060 ASSY-BUMPER,FRONT Truck 7804-8910 [CHROME + rubber]
  • 62650-95W00 ASSY-BUMPER,FRONT Truck from 8910 [BLACK + rubber]
  • 62024-G1060 BUMPER-FRONT [rubber end cap] RH from 7804
  • 62025-G1060 BUMPER-FRONT [rubber end cap] LH from 7804
  • 08360-61026 SCREW 7804-8910
  • 08911-10637 NUT 7804-8910
  • Side Brackets
  • 62672-H1001 BRACKET-FRONT BUMPER SIDE, RH
  • 62673-H1001 BRACKET-FRONT BUMPER SIDE, LH
  • 62663-G1050 BOLT-bumper "B" STD -7509 [side, exterior]
    • superceded 62663-15401 STD
  • 62663-27700 BOLT-CARRIAGE [side, exterior] -8503 CHROME METAL (CR-10S) (2)
  • 62663-G1900 BOLT [side, exterior] 8504-8910 CHROME METAL (CR-12S) (2)
  • 62663-G1205 BOLT [side, exterior] 8910- BLACK ハンツトヤノソウ (2)
    • 08915-43610 WASHER (2)
    • 08915-13610 WASHER-LOCK (2)
    • 08911-10610 NUT (2)
Carriage Bolts
  • 62678-21000 SHIM-BRACKET BUMPER (2)
  • 08360-61626 BOLT (fixing bumper side to fender)
    • replaced 08360-62014 -7509
      • 08915-43610 WASHER-plain -7509
  • Stays
  • 62670-H1002 STAY-FRONT BUMPER, RH
    • replaced 62670-H1001 STAY-front bumper (R.H.) (up to '72-6)
  • 62671-H1002 STAY-FRONT BUMPER, LH
    • replaced 62671-H1001 STAY-front bumper (L.H.) (up to '72-6)
  • 62663-G1050 BOLT-bumper "B" STD (4)
  • 62663-27700 BOLT-CARRIAGE (4) [external, to bumper] EXC STD
    • 08915-43610 WASHER-PLAIN (4)
    • 08915-13610 WASHER-LOCK (4)
    • 08911-10610 NUT (4)
  • 08124-23010 BOLT (4) [to body panel]
    • superceded 08114-25510 (from '72-7)
      • replaced 08110-81662 (up to '72-6)
    • 08915-14210 WASHER-LOCK (4)
    • 08915-44210 WASHER-PLAIN(4)
      • replaced 08915-53810 (up to '72-6)
  • Hook (-7509) Bolted to the front Bumper Stays
  • 62682-H7000 HOOK-tie down (R.H.)
  • 62683-H7000 HOOK-tie down (L.H.)
Rear
  • 85010-G1001 RUBBER-REAR BUMPER, SIDE RH 7611
  • 85010-G1002 RUBBER-REAR BUMPER, SIDE RH 7612-
  • 85011-G1001 RUBBER-REAR BUMPER, SIDE LH 7611
  • 85011-G1002 RUBBER-REAR BUMPER, SIDE LH 7612-
  • 08310-64512 SCREW [external] 7510-
    • 08915-43610 WASHER-lock
  • 08310-64510 SCREW [external] -7509
    • 08915-43610 WASHER-LOCK
  • 08110-61810 SCREW [internal]
    • 08915-13610 WASHER-LOCK 7510-
  • 90802-G1000 BUMPER RUBBER-TAIL GATE -7603
  • 90802-G1001 BUMPER RUBBER-TAIL GATE 7604-
  • 08310-62012 SCREW (2)
Photos
