TRX Wheels
Revision as of 04:27, 4 October 2016; view current revision
Category: Wheel And Tire
Alloy wheels from Datsun 910 "Bluebird Series II" Australia TRX package work nicely on a Datsun 1200.
TRX wheels appear to be identical to the Cheviot Mirage
6501.jpgAlbum 6501 2005.jpgAlbum 2005 14785.jpgAlbum 14785 10190.jpgAlbum 10190
TRX
Nissan Bluebird TRX rims
14821.jpgAlbum 14821 7841.jpgAlbum 7841
15" wheels, 5.5"(?) wide, Offset +35
Discussion: will trx 15"rims fit straight onto 1200 ute without flaring?
If I see another 1200 with TRX rims I'm going to smack you across the face!
On standard Datsun 1200 struts they will require fairly low profile tyres, and quite large spacers for the front and it will need to stay at standard height. Even then you might find they are a tight fit and might grab the guard a bit if you hit any speed humps too quick or take corners quick.
If it is lowered at all you will need to roll the guards for sure!
TRX wheels on 1200
With Stanza and other similar struts they fit no problem with 195/50R15 tyres and will only need to cut the front bottom corner out of the front guards for clearance when turning.
With Sunny (B310) struts on front and 195/50R15 tyres, it requires to roll all the guard lips, and run spacers on rear as they were scrubbing the inner guard and on all wheel arches the sharp lip all around the guard was tearing into the tyre slightly so rolled it right up.
Source
Japan TR-X
15x6 Offset +35
レパード TR-X Nissan F30 Leopard TR-X 8009-8602
F30 15x6 Aluminum
N1 TYPE アルミ ホイール
40300-F6025 ** F/AL KEYLESS 6JJX15 *L20E# 8406- 4
40300-F6026 ** F/AL W/KEY   6JJX15 *L20E# 8406- 1
40300-F6027 ** F/AL KEYLESS 6JJX15 OFFSET 35  VG30T 8406- 4
40300-F6028 ** F/AL W/KEY   6JJX15 OFFSET 35 *VG30T 8406- 1
40224-W1505 NUT-ROAD WHEEL $19.10 USD
* K10,910,B11,E23,F30,R30,M10,S12,U11,Z31
* USA: nut used on S12,Z31
Wheel Nuts
TRX wheels use a taper-seat nut. About 7$ each from Nissan, or $3 each from aftermarket sources. Can be purchased at wheel shops too.
There is 2 different types of trx wheels (series 1,2 + series 3). There is a extra small lip on the inside of the stud holes on series 3 and so the nuts differ a little
TRX Wheel nuts
Factory TRX nut at left, either kind will work
Aftermarket nuts can be used. Taper-seat Nut longer taper area required
Datsun 1000
1658.jpg 1996.jpg 2005.jpg 2098.jpg 2606.jpg 2794.jpg 2882.jpg 5796.jpg 6491.jpg 6492.jpg 7645.jpg 7926.jpg 8576.jpg 8839.jpg 9304.jpg 13281.jpg14785.jpg16846.jpg 16847.jpg 16848.jpg 16912.jpg 17446.jpg 17447.jpg 17768.jpg 22931.jpg
Posts
10076_501a730686985.jpgPost 414506 12703_4b18e9c81e530.jpgPost 294105 12703_4b2327d57549f.jpgPost 295223 16294_5047222d7c327.jpgPost 417185 2088_4ceb82286d864.jpgPost 347116 2088_4ceb82360debe.jpgPost 347116 3143_4ae03b308f97c.jpgPost 286908 3143_4c11c29cbd9f4.jpgPost 321594 3143_4f97d060db9e6.jpgPost 404889 3143_4fcc842b74f7b.jpgPost 408605 9264_4bd97c8858e66.jpgPost 314365 9361_4d847d1fea2e8.jpgPost 360499 9512_4ceae06ac36af.jpgPost 347075 9512_4ceae0bc7d164.jpgPost 347076 9512_4eaf7aafedfa3.jpgPost 387263 9512_4eb84ab577911.jpgPost 387986 9512_4eba57ee10f41.jpgPost 388189 9512_4f31cc7215bfd.jpgPost 397461
