Diff Baffles
Revision as of 23:34, 5 November 2017; view current revision
Categories: Rear Axle And Rear Suspension | Racing
The rear axle housing may be fitted with axle baffles. They are designed to constrain the differential oil to the center section. Otherwise when high-speed racing the oil can move to one side and stay there.
26211.jpgAlbum 26211
Datsun Competition H145 Axle baffles
18390.jpgAlbum 18390
These baffles can be installed in any Datsun equipped with an H145 rear axle assy.
  • 43015-25720 AXLE BAFFLE/RH
  • 43016-25720 AXLE BAFFLE/lH
Datsun Competition axle baffles welded into the housing
15737.jpgAlbum 15737
RS240 Setup (H190 diff) - At the rear there are two plugs fitted. The top plug is for checking oil level and the second for fitting an oil pickup for the diff oil cooler pump. The return from the cooler sprays directly onto the pinion gera to cool it.
5634.jpgAlbum 5634
