The engine-to-transmission Gusset bolts to the left side. The purpose is to stiffen the engine-transmission combination in order to reduce Noise, Vibration and Harshness (NVH).
CAST STAMPED 40mm bolts 30mm
30429 GUSSET 30429-H8501 B310 GUSSET A12S.F4-7811 + V-7909 [cast?] 30429-H8500 B310 GUSSET [stamped?] 30429-G1010 B120 GUSSET 7510- [cast?] Short Body only 30429-H5300 B210 (including all Van + except 5spd) 30429-H7302 B211.(60+56)
30422-H5010 B120 DUST COVER 7510- SB * Long Body uses an Engine Plate instead * all B310(?) uses an engine plate
56-series (including early B310) + B210.60 08130-83010 BOLT-gusset to block (2) [M8 alloy steel] 08915-13810 WASHER-gusset to block (2) [M8 spring lock medium] 08131-04010 BOLT-gusset to transmission (2) [M10 x 40mm alloy steel] 08915-14010 WASHER-gusset to transmission (2) [M10 spring lock medium]
B310.60-series + 56-series.B310.late 30210A 01111-00361 BOLT-gusset to block (2) 08915-13810 WASHER-gusset to block (2) [M8] 08131-03010 BOLT-gusset to transmission (2) [M10 x 30mm alloy steel] 08915-14010 WASHER-gusset to transmission (2) [M10 spring lock medium]
Cast Gusset
