Sunny Truck Wiring
Revision as of 08:11, 4 August 2019; view current revision
Categories: Sunny Truck | Body Electrical System | Engine Electrical System
19684.jpgAlbum 19684
Engine Room Harness assembly
* 24012-H1002 -7103
* 24012-H1004 -7103 OPTION
* 24012-H1206 7205-7204 [catalog appears to have a mistake]
* 24012-H1205 7205-7302 [catalog appears to have a mistake]
  some note about the old Coil connector
* 24012-G1400
* 24012-G1401 7303- > 24012-G1400
* 24012-G1604 7510-8012
* 24012-G1605 8101-8109
* 24012-G1900 8110-8503
* 24012-G1901 8504-8608
* 24012-G1902 8608-8910
* 24012-95W00 8910-
* 24013-95W00 HARNESS ASSY-INSTRUMENT 8910-
* 24014-95W00 HARNESS ASSY-BODY 8910-
* 24015-95W00 HARNESS ASSY-TAIL SB 8910-
* 24015-95W01 HARNESS ASSY-TAIL LB 8910-
Engine Room Sub-harness assembly (starter and transmission)
* 24077-G1600 7510-8910
* 24077-95W00 HARNESS ASSY-ENGINE ROOM SUB 8910-
Room Lamp harness assembly
* 24160-G1000 HARNESS ASSY-ROOM LAMP all early
* 24160-G1001 HARNESS ASSY-ROOM LAMP 7510-
* 24022-01E01 LINK-FUSIBLE 8910-
* 24310-95W00 BLOCK ASSY-FUSE 8910-
* 24311-92W00 COVER-FUSE BOX 8910-
Instrument Panel
25013
27518.jpgAlbum 27518
* 25160-H1101 SWITCH ASSY-LIGHTING all
  B5160-B6800 replaced the above $41.08 USD
* 25230-C9970 RELAY NILES ENGINE CONTROL 8910-
* 25230-C9980 RELAY MIYAMOTO ENGINE CONTROL 8910- $28.42 USD
  a 4-pin relay with a blue plastic housing in either Niles brand (25230-C9970) or Miyamoto brand (25230-C9980). Either of the two brands is interchangeable
  Used in many 1979-1997 Nissans
* 26320-89905 RELAY ASSY-PASSING LIGHT $13.45 [also used for horn relay]
* 25260-G1060 SWITCH ASSY-WIPER 8110-
  also 7804-8109 w/INTMT WIPER
* 28890-B8060 AMP-INTERMITTENT WIPER
* 24428-89900 BATTERY TRAY
Engine Control
* 22604-95W00 ENGINE CONTROL MODULE 8910-
* 22690-F5300 HEATED OXYGEN SENSOR, REAR 8910-
  replaced by 22690-17B00 $167.92 USD
Fuel
* 22360-01M00 SWITCH ASSY-VACUUM 8910- $80.50 USD
