Cigarette Lighter, now useful for 12V accessories power. It is on a 15 AMP fuse, so can power a 250 watt inverter.
Original 1200 style
Middle element is for early Datsun 1200, outer for late 1200 pickup
Lighter body fits into Dash panel and the threaded portion clamps it tight to the panel.
The ground is provided by the metal contact of body with Dash.
Element * B5330-H1001 ELEMENT-cigarette lighter $8.08 * B5330-H3101 ELEMENT-cigarette lighter 1972 JDM
Blocking plate for delete option * 24250-89973 PLUG-cigarette lighter STD $1.50
Complete assemblies: * 25330-H1000 LIGHTER COMP-cigarette early DX ** including PB110 ** superceded by B5331-H5001 $23.80 *: Also Sunny Truck -7803 * 25330-H3100 LIGHTER COMP-cigarette DX 1972 * 25330-H3101 LIGHTER COMP-cigarette (from '72-10) DX * 25330-B8001 B120 7804-8109 ** superceded by B5331-H5001 $23.80 * 25330-G1900 B120 8110- ** 25335-89950 ELEMENT ASSY-CIGARETTE LIGHTER B120 8110- $16.00 ** 25338-89900 PLATE-EARTH, CIGARETTE LIGHTER B120 8110-8109 $6.60
Illuminated with bulb, JDM GL, GX (including PB110) * 25330-H2000 LIGHTER COMP-cigarette with bulb early * 25330-H3400 LIGHTER COMP-cigarette 1972 * 25330-H3401 LIGHTER COMP-cigarette (from '72-10)
Comparison
Looks very similar to B110
25330-H5001 Illuminated (note wire)
B211
Nissan
Nissan 25331-89950 Cigarette Lighter *Replaces: 25330-W0509, 25330-W2400 25331-89951, 25331-89958, B5331-89958, 25330-N8200
620
The Cigarette Lighter has a single wire connection, a Blue (L) wire that comes out of the middle of the instrument panel wiring harness. It is grounded through the metal frame of the dash.
L - Blue wire +12V (round bullet connector) Not the longer LW (Blue/White stripe) which is adjacent
Since it is powered directly through the Fuse Box, the lighter socket works even when the key it out of the ignition.
Roadster 'CL'
