Trix
Revision as of 20:24, 1 May 2022; view current revision
Category: User Community
Club member Leon T. (Trix now trix1) is a dedicated 1200/1400 fan.
1400 Ute
Nissan 1400 (B140) bakkie in 2006 with AutoStyle front air dam
28195.jpgAlbum 28195
Now with 17s and Tonneau Cover
28196.jpgAlbum 28196 10444.jpgAlbum 10444
Classic double Rally_Stripes
10379.jpgAlbum 10379
17" Velocity Max tyres with Nismo valve stem caps
11264.jpgAlbum 11264
Turbo
turbo'd A14 with Fuel Injection
28197.jpgAlbum 28197 19196.jpgAlbum 19196 19197.jpgAlbum 19197
2020: turbo 3S-GE engine
28200.jpegAlbum 28200 28201.jpegAlbum 28201 28202.jpgAlbum 28202 28203.jpgAlbum 28203
Seats
2009: Alternative_seats
18326.jpgAlbum 18326 18325.jpgAlbum 18325 18324.jpgAlbum 18324 28198.jpgAlbum 28198 28199.jpgAlbum 28199
Coupe GX 2T Project
15663.jpgAlbum 15663
He proved that a sedan/ute windscreen can be made to fit a coupe in a pinch
15662.jpgAlbum 15662
body & paint work
18558.jpgAlbum 18558 18557.jpgAlbum 18557 18162.jpgAlbum 18162
2T Engine Swap
Toyota_T_Engine_Swap#Trix 2T 1600cc hemi-head motor with twin carburetors
19191.jpgAlbum 19191 18774.jpgAlbum 18774 18166.jpgAlbum 18166 18165.jpgAlbum 18165
Out comes the A14 and 60-series gearbox
18160.jpgAlbum 18160 17994.jpgAlbum 17994
2T fits nicely in the 1200 engine bay
18444.jpgAlbum 18444 18443.jpgAlbum 18443 18442.jpgAlbum 18442
1200 engine crossmember modded with angled horns (similar to a 1200-CA crossmember) with 2" clearnce (and boxed for strength)
18161.jpgAlbum 18161
30mm cut off to allow the 2T sump to fit
18161.jpgAlbum 18161 18441.jpgAlbum 18441
Engine mount brackets with Ford V6 rubber insulators
18458.jpgAlbum 18458
2T valve cover restoration (sandblasting, sanding, buffing with metal polish)
18164.jpgAlbum 18164 18327.jpgAlbum 18327 18328.jpgAlbum 18328
Exhaust Manifold fabrication
18163.jpgAlbum 18163
T50 5-speed
T50 splitter 5-speed close-ratio TRD gearbox
18439.jpgAlbum 18439
gearbox crossmember
Modding the 1200 tunnel for clearance
18440.jpgAlbum 18440
Brakes
Rear_Disc_Brakes#Trix Civic caliper with Skyline discs
18773.jpgAlbum 18773 18772.jpgAlbum 18772 19195.jpgAlbum 19195 19194.jpgAlbum 19194 19193.jpgAlbum 19193 19192.jpgAlbum 19192
