The Datsun A12 engine is the most common A series engine to be found. They are commonly found in most countries and were fitted to the B110, B210, & B310 chassis, known as the Datsun/Sunny 1200,[B110] Sunny/120y, [B210] & Sunny/120Y [B310]. The US model B210 [B210] & model 210 [B310] did not use the A12 engine.
All A series engine blocks, from the 7/73, were modified with a different method of passing oil from the block to the head for rocker shaft oiling, the distributer moved back, both engine mount brackets moved back 40mm and the altenator swapped from a low left position to a high right one. This was all done to make room for an airconditioning compressor mounting point in the former alternator mounting area.
Specifications:
