Econometer
Revision as of 02:07, 14 January 2025; view current revision
Category: Fuel System
29826.jpgAlbum 29826
Search: サニーエコノモニター Sunny Economonitor
Search: サニーエコノメーター Sunny Econometer
A fuel-economy gauge signals to the driver the current engine state as it relates to fuel economy. Red or Yellow means poor fuel economy, Green means good fuel economy. This most directly relates to how far the accelerator pedal is pushed, so you might think the gauge is of limited use. However, up to 30% fuel economy gains can be achieved by tailoring your driving style to match. It is surprising how easing up on the pedal will affect economy, while still accelerating the car.
The Datsun gauge for the B210 was called was called Econo Meter/エコノメーター. The B310 version of the econometer (per Datsun catalog) was called Economonitor in Australia and ECONO MONITOR エコノモニター in Japan.
In operation, a green light appears at low throttle openings, and a red light at heavy throttle. It is of course a type of vacuum gauge. Does it work to enhance fuel economy? Yes. By keeping acceleration light, the driver can achieve fuel savings up to 30%. And yet you still have maximum power available, should you decide to put your foot down and throw economy to the wind.
In more general use, consider this quote by Bosch:
An Econometer is merely a vacuum gauge with different markings to directly indicate the economy benefits of each area of vacuum operation.
Cars in the new millenium often have a fuel-consumption gauge which gives an instantaneous reading of liters/kilometer or miles/gallon. The econometer is a simpler technology, and perhaps is more enlightening to the driver.
Some new cars have an electronic fuel-economy gauge, with red/green lights or a power/eco readout. This works the same as an econometer and is based on vacuum.
<-- back to B210 Gauges
For Japan, after '75-10 an Econometer (vacuum gauge) was fitted to the GL, in the tachometer spot (round or square). Since the tachometer was standard on GX, the Econometer was not available on the performance-oriented model.
29830.jpgAlbum 29830 29826.jpgAlbum 29826
29835.jpgAlbum 29835
Round
29830.jpgbrochure
1600 GL
29831.jpgbrochure
Square
174_5c10d16698212.jpgPost 490146 25298.jpgAlbum 25298
with vacuum hose cut short and early B210 wiring (single-lead bulbs, earthed via metal back)
174_5c10d17414206.jpgPost 490146 174_5c10d181b6805.jpgPost 490146
with K/S 合格 Passed mark
early B210 econometer with factory vacuum tank
29836.jpgAlbum 29836 29837.jpgAlbum 29837 29838.jpgAlbum 29838
Kanto Seiki [K/S]
29827.jpgAlbum 29827 29832.jpgAlbum 29832
With late B210 wiring (multi-connector, two-lead bulbs with earth wire)
29839.jpgAlbum 29839 29840.jpgAlbum 29840 29841.jpgAlbum 29841
29828.jpgAlbum 29828
エコノメーター(1600·1400GL系)。省燃費時代に対応。経済走行の指針です。 Econometer (1600/1400GL series). A guide to economical driving, in keeping with the current fuel-saving era.
Parts
Catalog C-402 for JDM 1975-1976 B211 and late VB210
29834.jpgAlbum 29834
24895 ECONOMETER ASSY エコノメーター アッセンブリー
24895-H7000 SQUARE S.A14,L16.GL *S.A12
24895-H7410 ROUND K.A14S,L16.GL *K.A12S
24895E BAND-HOSE バンド、ホース
14896-25600 A14,L16.GL *A12
* Many, many Nissan and Datsun models
24898E BAND [CLIP]
24220-N3301 A14,L16.GL -7601
* Replaced by 24220-B5020
24220-U6500 A14,L16.GL 7602-
24895K ECONOMETER KIT エコノメーター キット
24893-H7425 SQUARE *S.A12 *V.A12
24893-H7426 ROUND *S.A12
24898 TANK ASSY-VACUUM タンク アッセンブリー、バキュム
24898-M5610 A14,L16.G *A12
24899 HOSE-VACUUM ホース、バキュム
27665-H7900 A14,L16.GL *A12
24899E CONNECTOR コネクター
27029-P0100 *A12 -7701 F/AIRCON HOSE T-CONNECTOR
            *S,K.A12S+H=T 7702- F/AIRCON
27614-78200 *A12 7702- F/INTAKE MANI
27614-78200 *S,K.A12S+H=T 7702- F/INTAKE MANI
B310
<-- back to B310 Dash
With the B310 meter, a green light appears at low throttle openings, and a red light at heavy throttle. This indicates the relative fuel economy.
24895-H9000 ECONOMONITOR ASSY GL,SGL -7811 [large type]
24895-H9010 ECONOMONITOR ASSY GL,SGL 7812-7909 [small type]
H9010 ECONO MONITOR Japan in GL dash small gauge on right side along with EXH TEMP and BRAKE lamps
174_5c10d1413b248.jpgPost 490146 174_667b1b283292b.jpgPost 498532
H9000 Round dash early -7811 with lights for OIL and CHG. The tubes on the back are for the bulbs
29594.jpgAlbum 29594 29595.jpgAlbum 29595
Aftermarket
S-Light ECONO METER 集中式操作盤 Centralized Operation Panel
29829.jpgAlbum 29829
Sun EconoMeter ECM-30
29833.jpgAlbum 29833
Sun Electric Corporation Tachometer Division Chicago, Illinois USA
Sun was a manufacturer of diagnostic tools for the automotive industry. Founded in 1931, they merged with Snap-on in 1993. In 2025, Snap-on diagnostic products are sold in Europe and Brazil under the name Sun. Since the 1980s Sunpro was the market name in the USA, but now discontinued after Bosch bought Actron.
SUNTUNE CP7965 Econometer Gauge Kit (Suntune products by Pentron), later Actron CP7965
29795.jpgAlbum 29795 27635.jpgAlbum 27635
Suntune ECONO METER
CRYPTON Econometer DRIVING GAUGE MODEL NO B.1. (Complementary Instrument B1)
British manufacturer Krypton. The internal disk rotates and the color changes
29699.jpgAlbum 29699 27310.jpgAlbum 27310 27195.jpgAlbum 27195 27633.jpgAlbum 27633
The Crypton brand is now owned by Continental AG, along with VDO gauges
