Consumer Information
Revision as of 02:54, 15 March 2025; view current revision
Category: Documentation
<-- back to Documentation
This Nissan Motor Corp. in U.S.A. publication has specifications for passing, braking, and tire load for all Datsun passenger-car models for a given year.
Federal Highway Administration Part 375.101 mandates an auto manufacturer publish Passing, Braking and Tire Reserve Load Data for passenger cars manufactured on or after January 1, 1970.
NHTSA put out booklets with the data from all the manufacturers e.g.:
1971
1971 Datsun Consumer Information
254.jpgAlbum 254
VEHICLE STOPPING DISTANCE
256.jpgAlbum 256
Description of vehicles to which this table applies
DATSUN 1200 SEDAN, DATSUN 1200 COUPE
A. Fully operational service brake
   Load Light: 195
   Maximum:    190
   Stopping distance in feet from 60 mph.
B. Emergency service brakes: 595
   (with partial service brake system failure)
1973
(green cover)
Title: Consumer Information [green on white]
1973 240Z,510,610,1200 B110
Format:16 page booklet Size: Publication Number:CI3E-ALLMU3
Cover
CONSUMER INFORMATION
1973_00.thumb.jpg.de0ccaeff8bafe28cf9df4f4d5c26bef.jpgRatsun
DATSUN
NISSAN MOTOR CO., LTD. Tokyo, Japan
Introduction
Dear Datsun Owner:
To find your vehicle information, refer to the charts indicated by a check. If no checks are made, have your Datsun Dealer check the column applicable to your vehicle.
INTRODUCTION
NOT reading the following may be harmful to YOUR health.
The figures contained in the summary following apply to all DATSUN vehicle in the particular group.
In compliance with the National Traffic and Motor Vehicles Safety Act (15 U.S.C. 1401, 1407), our DATSUN cars have been tested extensively and the results compiled to cover completely our total range of automobiles.
It is essential, we feel, that our users should carefully study the data before driving their new DATSUN so that they are familiar with the potential ability of the car, PRIOR to using it.
The U.S. Federal Government's Road Traffic Authority has carefully evaluated the statistics relating to the following minimum safety figures and has laid down specific guidelines that we, the manufacturers, most use when arriving at the figures stated in the following pages.
We at Nissan Motor Company of Tokyo, Japan, would like to state that the following figures are accurate and representative but in the event of drivers NOT following our recommendations regarding servicing, tire pressures, etc., we cannot accept responsibility for any injuries, damage, etc., apart from the parts covered under the usual Nissan Warranty which SPECIFICALLY states that our recommended procedures must be followed carefully in order to validate the warranty.
NISSAN MOTOR CO., LTD. TOKYO, JAPAN
This figure indicates braking performance that can be met or exceeded by the vehicles to which it applies, without locking the wheels, under different conditions of loading and with partial failures of the braking system. The information presented represents results obtainable bry skilled drivers under controlled road and vehicle conditions, and the information may rat be correct under other conditions.
5 MODEL B110
DATSUN 1200 SEDAN, DATSUN 1200 SEDAN AUTOMATIC, DATSUN 1200 COUPE, DATSUN 1200 COUPE AUTOMATIC
   Load Light: 195
   Maximum:   190
C. Brake power unit failure
   Maximum load [not applicable]
TIRE RESERVE LOAD
TIRE RESERVE LOAD
This table lists the tire size designations recommended by the manufacturer for use on the vehicles to which it applies, with the recommended inflation pressure for maximum loading and the tire reserve load percentage for each of the tires listed. The tire reserve load percentage indicated is met or exceeded by each vehicle to which the table applies.
* "The difference, expressed as a percentage of tire load rating, between (a) the load rating of a tire at the vehicle manufacturer's recommended inflation pressure at the maximum loaded vehicle weight and (b) the load imposed upon the tire by the vehicle at that condition.
WARNING: Failure to maintain the recommended tire inflation pressure or to increase tire pressure as recommended when operating at maximum loaded vehicle weight, or loading the vehicle beyond the capacities specified on the tire placard affixed to the vehicle, may result in unsafe operating conditions due to premature tire failure, unfavorable handling characteristics, and excessive tire wear. The tire reserve load percentage is a measure of tire capacity, not of vehicle capacity. Loading beyond the specified vehicle capacity may result in failure of other vehicle components.
16 MODEL B110
Description of vehicles to which this table applies:
Recommended cold inflation
       6.00.12-4PR   1556812
Front: 22            24
Rear:  24            24
Pressure for maximum loaded vehicle weight
Tire reserve load percentage *
       3.0           13.0
Back Cover
NISSAN
DATSUN
2nd Revised Edition
Issue date: 10th September 1972 (165000)
Printed in Japan Publication No. CI3E-ALLMU3
