Clarion 1006
Revision as of 07:21, 25 March 2025; view current revision
Categories: Body Electrical System | Options
<-- back to Radio
クラリオン (Clarion) AM Radio for late model 1991-1994 B120 Sunny Truck
Model: Clarion 1006M Dial: [C 5³-7-10-13-16]
Year: 1991-1994 Faceplate hole: yes
Market: Japan Buttons: blank smooth
30284.jpgAlbum 30284
RN-1006M
28011-95W00 RADIO KIT 9107- A403
With u-shaped 8-pin wiring connector
20211.jpgAlbum 20211
* black bezel
* dial markings on window of radio body
* 8-pin connector
* black knobs
* blank push-buttons with rounded ends
Dial markings are on the radio, not on the bezel
'C 5³-7-10-13-16' where C is the Clarion pre-2012 symbol
Clarion PART NO. 286-7712-00
30281.jpgAlbum 30281
With dial window hole (top left corner)
30285.jpgAlbum 30285
Black inner and outer knobs
30286.jpgAlbum 30286
Bottom has two mounting screw holes (not utilized on Datsun 1200)
30288.jpgAlbum 30288
Nifty detachable antenna connector jacks into the radio with a u-bend
30291.jpgAlbum 30291
with rear bracket attached. Note the large step-up of the bracket to compensate for the short body height
18711.jpgAlbum 18711 16433.jpgAlbum 16433 30287.jpgAlbum 30287 30289.jpgAlbum 30289 30290.jpgAlbum 30290
Dimensions
Clarion 1006M is a compact radio, apropos for the 1990s version of the Datsun 1200 radio. The depth is about half of the oldest radios. In addition, the body is of shorter height than previous models, necessitating a step-up top bracket
* depth: body 60mm faceplate-to-rear-body: 70mm
* height: body 50mm
* width: body 160mm
30282.jpgAlbum 30282 30283.jpgAlbum 30283
