1400 Bakkie
Revision as of 03:33, 24 November 2025; view current revision
Categories: Documentation | Sunny Truck
<-- back to South Africa Brochures
You find us building front-wheel drive cars. But not front-wheel drive bakkies. #Never.
1986 NISSAN tailgate
     Rectangular headlights
     Formula 1 bred disc brakes
Index
31320.jpg#flyer 31321.jpg#flyer
31330.jpg#brochure31322.jpg#Perfection31331.jpg#Features/Specs
31323.jpg#Engine31324.jpg#Suspension 31325.jpg#Comfort31326.jpg#Brakes
31327.jpg#Uniprime31328.jpg#Uniprime31329.jpg#Improvements
Brochure
Title: 1400 Bakkie [white Nissan 1400]
1985.12 South Africa bakkie B140
Format:8 page booklet + two overleaf pages Size:295 x 210mm Publication Number:AD 001 B140 RA
Never
outside sheet overleaf page
What makes us different is what makes us better.
31330.jpgAlbum 31330
We've always taken the view that what's right for our cars is not necessarily right for our bakkies. Which is why you find us building front-wheel drive cars. But not front-wheel drive bakkies. Never.
The reason being that — despite the trendy fashion towards 'bakkies' that are really cut-off passenger cars with a load box tacked on the back — our bakkie has always had rear-wheel drive.
Why? Simple. The back is where you carry the load.
To operate effectively and successfully with a load, there's only one right place for that to be. Over the traction wheels.
So you'll never see our 1400 bakkie with anything but rear-wheel drive.
Meaning the heavier you load it, the harder it will work for you. No matter what the others do. Because we're building bakkies to match our indestructible engines.
1400 BAKKIE
 NISSAN
We are driven
Perfection
when folded, this is the front cover
It's not easy to improve on 16 years of perfection.
But our 1400 bakkie proves it's possible.
31322.jpgAlbum 31322
1400 BAKKIE
 NISSAN
We are driven
Features and Specifications
when folded, this is the back cover
#Features | #Specifications
31331.jpgAlbum 31331
Features.
STANDARD FEATURES
INTERIOR
* Heater/Demister
* Glove box with latch
* Warning lights for: handbrake
  oil pressure
  no charge
  hazard warning
* Bench seats with perforated vinyl inserts
  (std only)
* Interior seat belts
* Interior courtesy light
* Floor mounted handbrake
* High quality moulded floor carpets in cab
* Locking steering column
* Curved rear window
EXTERIOR
* Front black bumper
* Opening door vent windows
* Dual exterior mirrors
* Rear window protection bars
* Styled pressed wheels
* Half wheel cover
ADDITIONAL FEATURES FOR DELUXE MODELS
* Door armrests
* Cigarette lighter
* Clock
* Cloth door insert panel
* Individual seats
* Cloth facing
* Day/night rearview mirror
* Trip meter
* Body protection side mouldings
* Alloy wheels
* Tonneau cover
* Semi matt-black radiator grille
* Chrome exhaust extension
* Instrument panel dimmer switch
Specifications.
ENGINE
Engine Type                             4 Cylinder OHV
Displacement (cm)                       1397
Bore + stroke (mm)                      76 x 77
Compression ratio                       9.4
Max. Power Kw @ rpm (SABS)              47@6000
Max. Torque Nm @ rpm (SABS)             97@2500
Fuel supply
     Hitachi dual barrel downdraught carburettor
Fuel tank capacity (ℓ)                  37
SUSPENSION
Front        Independent strut type with coil springs &
             stabiliser bar
Rear            Live axle, Semi-elliptic leaf springs
Shock absorbers              Telescopic double-acting
WHEELS
STANDARD             4Jx12 pressed steel
DELUXE               5.5Jx12 alloy
spare                4J x 12 pressed steel
TYRES: Type & Size                Radial Ply 155SRx12
STEERING: Type                    Recirculating ball
TURNING CIRCLE (m)                        8.2
BRAKES: Type     Power assisted, dual line with front
                 discs and rear drums
ELECTRICAL SYSTEM             12V - 45AH negative earth
Battery - Type + Capacity                  45A
COOLING SYSTEM Pressurised radiator with centrifugal pump
Capacity (ℓ)                               4.7
TRANSMISSION Type                     4-speed manual
Ratios             1st                  3,757
                   2nd                  2,169
                   3rd                  1,404
                   4th                  1,000
Final Drive                             3,89
Reverse                                 3,640
Drive Wheels                            Rear
DIMENSIONS: (mm)
Overall length                          3845
Overall Width                           1495
Overall Height                          1425
Overall wheel base                      2300
Overall ground clearance                160
BOX DIMENSIONS
(Floor) Length                          1518
(Floor) Width                           1285
        Height                           415
MASSES                             Standard Deluxe
       Tare Mass                     758     774
       G.V.M. Kg                    1394    1394
        Gross Payload Kg             591     575
1400 BAKKIE
 NISSAN
We are driven
Part No: AD 001 B140 RA
Effective date: December 1985
All illustrations and specifications in this brochure are based on the latest information available at time of publication. Nissan S.A. (Pty) Ltd. reserves the right to make changes at any time, without notice, in prices, colours, materials, equipment, specifications, and models, and to discontinue models or equipment. For information on options and
accessories, please contact your local Nissan dealer.
BM LITHO 29887
Engine
Making engines like ours can be a very hard act to follow.
31323.jpgAlbum 31323
[image: engine with orange air cleaner and Lucas AS123 alternator]
Farming out in the far north-west can be hard.
On men and machines.
On Hannes Louw's Vryburg farm, so rough that his 16 year old bakkie eventually couldn't take it any more.
That was about 5 years ago.
Since when its stout-hearted 1300 engine has continued to run tirelessly. Year in, year out. Pumping water. Generating power.
However making engines that never wear out has given us a problem. A challenge. To be able to build bodies as everlasting and unbreakable as our Nissan engines and drive trains always are.
And that's what we're doing now.
Building them better. And stronger. Utilising South Africa's most advanced rustproofing technology. That belongs to Nissan and Nissan alone.
So your new bakkie can last as long as its legendary engine.
Because that's your need.
We are driven
Bone-shaker
If this bone~shaker can't break it, neither can you.
31324.jpgAlbum 31324
At Nissan, we must have some of the most positively bloody-minded quality control engineers in the world.
Who take a fierce delight in trying to wreck cars. And bakkies.
Bakkies especially.
Because they know yours is going to be put to work. Hard.
Over rough roads. Or over no roads.
Driven to the limit. Maybe by people who won't take as much care of it as you would.
So for our bakkies they developed the most fiendishly-destructive test track that nasty suspicious minds could conceive. A circuit actually worse than anything you could ever possibly drive over. (In fact that piece of washboard you can see is one of the better sections). Then they take a bakkie across it at joint-wrenching speeds. To see if they can make something break. Or crack. Or squeak. At speeds so high they have to wear kidney belts to prevent their own bodies from falling apart.
We are driven
Comfort
Now,extra comfort. Surrounded by a big new cab for 3.
31325.jpgAlbum 31325
Since there's always room for improvement, that's what we did.
By making our little 1/2-tonne bakkie's cab a whole lot bigger. With more people space. For legs and heads and shoulders and hips.
With 30 mm more height so you get much more effective head room. Meaning you can sit relaxed and comfortable. Regardless of how tall you are.
Along with more head room we've also added 55 mm extra leg room. So you can stretch out. With plenty of clearance for your knees. And finish a long day or trip still rested and fatigue-free.
But cab comfort goes further than that. Now with position adjustments to our softer, smarter more comfortable seats. On both the 2-position 3-person bench seat in our Standard model, or the body-hugging cloth bucket seats in our de Luxe.
Both now come with creature comforts such as fresh air vents, inertial reels, 3-speed heater/demister, courtesy light, lockable glove box and day/night mirror with de Luxe adding in instrument illumination fading, an analogue clock, a parcel tray and thick carpeting to its better finish overall. On both, a new curved rear window that cuts out reflections is also standard. Our new 1400 half-tonner.
Because when you've been tops for so long you owe it to your customers to keep out in front.
We are driven
Brakes
Nothing ever matched our acceleration. Until now.
31326.jpgAlbum 31326
There's never been any doubt about what a super little goer our 1400 has always been.
With nothing in its class to touch it. Plus a lot of others in bigger and more powerful classes.
As we always knew it could go, we decided to stop it. Just as fast.
So we put disc brakes up front.
Nissan's famous Formula I bred fade-free discs.
To stop you quicker ... even fully-loaded. In traffic panic stops.
With lighter pedal pressures. Assisted by vacuum boost and the load sensing valve built into our dual hydraulic system.
With vastly improved directional stability under wet conditions.
All in all, much stronger and safer stopping power.
To make our heroic 1400 better than ever.
We are driven
Uniprime
Before getting our delivery OK ~ first 3 hard years in Durban.
31327.jpgAlbum 3132731328.jpgAlbum 31328
Before you ever get to see your new bakkie, one out of every batch faces the toughest, most demanding test for weatherproofing ever thought of.
First we put it through our unique 15-stage corrosion-proofing process. South Africa's most advanced technology. Absolutely state-of-the-art.
To protect it. With a process unique to Nissan. Called Uniprime.
That deposits a 40-micron thick tenacious rustproofing coat. (That's about twice as good as the next best electrocathodic process). Then we take that bakkie and subject it to accelerated tropical heating. To pressure salt spraying. And to rough-road driving to drive the deadly salt crystals deep into the seams.
Then we bake it, spray it and flex it all over again. For 3 weeks.
Equivalent to 3 hard years work at the coast.
Finally we tear it apart. Literally. Seam by seam. Weld by weld. All 5 000 or so of them. Ending up with a pile of battered body panels.
To prove to ourselves what we really knew. That our rustproofing really proofs.
Then — and only then — are the other bakkies from the same batch released for delivery. To you. So you can be absolutely sure of yours.
Wherever it goes.
We are driven
Improvements
[image: removable rear window guard bars]
[image: rectangular headlights]
[image: tailgate chains]
Our business end.
Now even more businesslike.
31329.jpgAlbum 31329
Since we've always believed in changing anything that we could for the better ... and not changing anything that couldn't be improved — over the years our B140 bakkie has kept up with the times.
Just recently we decided (since you work them so hard) it was time to upgrade the business end.
To make it work even harder for you.
So here are some of the changes for the better we've made.
We made the rear window bars removeable.
We added rubber down stops and chains to the tailgate for when you want to carry long loads.
We also installed a fuel tank inspection plate. And added body side protection mouldings to our de Luxe.
So you can get more business from your bakkie.
We are driven
Flyer
1986.02 South Africa bakkie B140
Format:single-sheet, two sides Size:295 x 210mm Publication Number:AD 002 B140 SDX
1400 Bakkie Standard/Standaard & Deluxe
31320.jpgAlbum 31320
1400 BAKKIE
 NISSAN
We are driven
Ons het dryfkrag
Specifications/Spesifikasies
We are driven NISSAN Ons het dryfkrag
31321.jpgAlbum 31321
ENGINE/ENJIN
Type/Tipe         4 Cylinder OHV/4 Silinder Kopklep
Displacement/Verplasing (cm)            1397
Compression ratio/Kompressieverhouding  9.4
Bore & stroke (mm)/Boring en slag (mm)  76 x 77
Max. Power Kw @ rpm (SABS)/             47 @ 6000
Maks. Krag Kw @ r/min (SABS)
Max. Torque Nm @ rpm (SABS)/            97 @ 2500
Maks. Wringvermoe Nm @ r/min (SABS)
Fuel supply/Brandstottoevoer
     Hitachi dual barrel downdraught carburettor/
     Hitachi dubbelkeel-valstroom-vergasser
Fuel tank capacity (ℓ)/                 37
Brandstofinhoudsmaat (ℓ)
SUSPENSION/VERING
Front/Voor
Independent strut type with coil springs & stabiliser bar/
Onathanklik stuttipe met kronkelvere en stabiliseerstaaf
Rear/Agter
Live axle, Semi-elliptic leaf springs/
Draaias, Halfelliptiese bladvere
Shock absorbers/Skokbrekers
Telescopic double-acting/Teleskopiese dubbelwerkende
WHEELS/WIELE
STANDARD/STANDAARD   4Jx12 pressed steel/Persstaal
DELUXE               5.5Jx12 alloy/allooi
spare/noodwiel       4J x 12 pressed steel/persstaal
TYRES: Type & Size/BANDE: Tipe & Grootte
Radial Ply/Straallaag 155SRx12
STEERING: Type/STUUR: Tipe
Recirculating ball/hersirkuleerkoeël
TURNING CIRCLE/DRAAISIRKEL (m)           8.2
BRAKES: Type/REMME: Tipe
Power assisted, dual line with front discs and rear drums/
Kraghulp-dubbelleiding met skywe voor en trommels agter
ELECTRICAL SYSTEM/ELEKTRIESE STELSEL
Battery-Type & Capacity/Battery-tipe & Vermoë
12V-45AH negative earth/negatiewe aarde          45A
COOLING SYSTEM/KOELSTELSEL Capacity (ℓ)/Kapasiteit (ℓ)
Pressurised radiator with centrifugal pump/
Drukverkoeler met sentrifugale pomp              4.7
TRANSMISSION/TRANSMISSIE Type/Tipe
4-speed manual/spoed handrat
Ratios/Verhoudings 1st/1ste             3,757
                   2nd/2de              2,169
                   3rd/3de              1,404
                   4th/4de              1,000
Final Drive/Eindaandrywing              3,89
Reverse/Trurat                          3,640
Drive Wheels/Aandrywingswiele         Rear/Agter
DIMENSIONS/AFMETINGS mm
Overall Length/Totale Lengte            3845
Overall Width/Totale Breedte            1495
Overall Height/Algehele Hoogte          1425
Wheelbase/Totale Asafstand              2300
Ground clearance/Grondvryhoogte           160
BOXDIMENSIONS/KASAFMETINGS(mm)
(Floor) Length/(Vloer) Lengte           1518
(Floor) Width/(Vloer) Breedte           1285
Height/Hoogte                            415
MASSES/MASSA's:              Standard Deluxe
Tare Mass/Tarramassa Kg              758     774
G.V.M. Kg/B.V.M. Kg                 1394    1394
Gross Payload Kg/Brutoloonvrag Kg    591     575
STANDARD FEATURES:
INTERIOR: Heater/Demister. Glove box with latch. Warning lightsfor: handbrake, oil pressure, no charge, hazard warning. Bench seats with perforated vinyl inserts (std only). Inertial seat belts. Interior courtesy light. Floor mounted handbrake. High quality moulded floor carpets in cab. Locking steering column. Curved rear window.
EXTERIOR: Front black bumper. Opening door vent windows. Dual exterior mirrors. Rear window protection bars. Styled pressed wheels. Half wheel cover.
ADDITIONAL FEATURES FOR DELUXE MODELS: Door armrests. Cigarette lighter. Clock. Cloth door insert panel. Individual seats. Cloth facing. Day/night rearview mirror. Trip meter. Body protection side mouldings. Alloy wheels. Tonneau cover. Semi matt-black radiator grille. Chrome exhaust extension. Instrument panel dimmer switch.
STANDAARDKENMERKE:
BINNEKANT: Verwarmer/ontwasemer. Sluitbare paneelkissie. Klikliggies vir: handrem, oliedruk, battery laai nie, noodwaarskuwing. Banksitplek met geperforeerde vinielinsetsels (net std). Oprol- sitplekgordels. Hoflikheidsliggie. Handrem op vloer. Hoë-gehalte gevormde tapyt in kajuit. Sluitbare stuurkolom.
BUITEKANT: Swart buffer voor. Deursyvenstertjie wat oopmaak. Twee buite-truspieëls. Beskermstawe vir agterruit. Gestileerde persstaal-wiele. Halwe wielbedekking. Geboë agterruit.
BYKOMENDE KENMERKE VIR DELUXE-MODELLE: Armleunings aan deure. Sigaretaansteker. Horlosie. Materiaalinsetsels in deurpanele. Afsonderlike sitplekke. Materiaalbelegsel. Dag/Nag-truspieël. Ritmeter. Gevormde bakskermstroke. Allooiwele. Bakseil. Semi- dofswart verkoelerrooster. Verchroomde uitlaatverlengstuk. Instrument-verdowingsliggie.
Part No/Onderdeelnr: AD 002 B140 SDX
(Effective date/Effektiewe datum: February/Februarie 1986
available at time of publication. Nissan S.A. (Pty) Ltd. reserves the right to make changes at any time, without notice, in prices, colours, materials, equipment, specifications, and models, and to discontinue models or equipment. For information on options and accessories, please contact your local Nissan dealer.
Alle illustrasies en spesifikasies in dié brosjure is gebaseer op die jongste inligting beskikbaar ten tye van publikasie. Nissan S.A. (Edms) Bpk. behou die reg voor om sonder kennisgewing ter enige tyd veranderings aan te bring in pryse, kleure, materiale, toerusting, spesifikasies en modelle en om modelle of toerusting te staak. Skakel asseblief u Nissan-handelaar vir inligting oor opsies en bykomstighede.
BM LITHO                                       14692
