Window Winders
Revision as of 03:32, 28 November 2025; view current revision
Category: Interior
Window regulator handles (window winders/window cranks) came in black, brown and gray. They are the screw-on type.
22016.jpgAlbum 22016 22017.jpgAlbum 22017
1972 USA Owners manual (Page 07 ... ):
Open [anti-clockwise] ... Close [clockwise]
1200 winders fasten to the door with a single screw.
20001.jpgAlbum 20001
Black: 1970-1977
Brown shade 1: 1978
Brown shade 2: 1979-1989
Gray: Oct 1989-
22018.jpgAlbum 22018 22027.jpgAlbum 22027
* 80675-H1000 WASHER-SEATING
* 08330-51220 SCREW
* 80760-H1000 HANDLE ASSY-DOOR WINDOW REGULATOR BLACK (B110/B120/PB110)
* 80760-G1060 HANDLE ASSY-DOOR WINDOW REGULATOR BROWN 7804-7907
* 80760-G1660 HANDLE ASSY-DOOR WINDOW REGULATOR BROWN 7908-8910
* 80760-95W00 HANDLE ASSY-DOOR WINDOW REGULATOR [GRAY] 8910-
willieoec-img600x450-1327303738hd43s518611.jpg willieoec-img600x450-1327303738yzrx2s18611.jpg willieoec-img600x450-1327303739ypr8hc18611.jpg
B140
Nissan 1400 B140 used a clip-on winder These are similar to #620 Pickup and #B310 winders.
Earlier B120 (to 1979) used the same as other 1200s.
31359.jpgAlbum 31359
1980-2008 brown winder
1990-2008 grey winder
31355.jpgAlbum 31355
aftermarket dark gray and black
31360.jpgAlbum 31360
A flat fork tool is used to remove the handle. Slip it between the handle and the door finishing panel, and push the clip off.
door window crank clip tool
Comparison
Compare to Datsun 1000:
2180.jpgAlbum 2180
Compare to Datsun B210, which may work on 1200:
25025.jpgAlbum 25025
Compare to Datsun B310, which are snap-on clip type:
620 - looks like the B310 units
80760-B5000 (Black) & 80760-B9800 (Brown, 1979)
Billet
Universal fit billet aluminium window winders have 3 different types of mounting hardware
11329.jpgAlbum 11329
Electric
Window Regulator
The regulator is the mechanism that raises and lowers the window glass. Technically, the front sedan & coupe regulator differ, however I have used the coupe regulator in a 2-door sedan.
coupe regulator (front door)
1916.jpgAlbum 1916
Image Search: サニトラ ウインドー ハンドル
sedan regulator (front door)
willieoec-img600x450-1327305561x5vbyb63892.jpg willieoec-img600x450-1327305560sffu2j63892.jpg willieoec-img600x450-1327305560jq4b9863892.jpg
ドア ウインドー レギュレーター ハンドル
