Clutch Diagnoses
Revision as of 08:06, 30 June 2007; view current revision
Category: Clutch
Noise when pedal pressed
Noise when pedal released
Clutch Won't Release Fully (difficult to shift gears
  • improper adjustment of linkage
Grabby clutch
  • Drum shoe brakes too tight, or contaminated with oil or grease. Inspect drum brakes
  • Oil or grease on clutch face
  • Disc rivets loose
  • Poorly lubricated clutch disc splines
  • warped pressure plate
  • Misaligned clutch. Make sure there is no junk between gearbox
  • worn clutch cable (common with RHD clutches)
  • Worn lining. Replace disc
Clutch Slips
  • worn disc
