NES Part Numbers
Revision as of 23:04, 24 May 2009; view current revision
Nissan Engineering Section (N.E.S.) specified six- to nine-digit Part Number formats for bolts and screws and other small hardware. During the 1970s these numbers were replaced by regular 10 digit Nissan Part Numbers.
Also See: Nissan Part Numbers
NES hardware parts originally used this six-digit format:
Type + Kind + dimensions (d) + length (L)
  t-kddLL or t-kkdLL
  e.g: 1-10612
In the mid 1960s, the digit '8' was added to the beginning:
 81-10612
Example:
  • 81-10612 BOLT, fixing timing chain tensioner support [B10 model]
    • Part: 81: Hexagon bolt
    • Kind: 1= Low carbon steel
    • Dimension: 06=6mm diameter thread
    • Length: 12=12mm
Example:
  • 9-16114 WASHER-lock to fix timing chain tensioner [410 model]
    • New number would be 89-16114
    • Part-Kind: 9-16: Washer, Tooth-lock
    • Shape & material: 1=Spring-lock medium thickness
    • Dimension: 14=14mm
Kind
1- Bolts
  • 11ddLL: Hexagon bolt, Low carbon steel
  • 12ddLL: Hexagon bolt, Medium carbon steel
  • 13ddLL: Hexagon bolt, Alloy steel
  • 81-4ddLL:
  • 81-5ddLL:
  • 81-6ddLL:
  • 17dLLL: Carriage bolt, Round head
  • 18dLLL: Carriage bolt, Flat head
  • 19dLLL: Carriage bolt, Step
2- Studs
  • 21ddLL: Stud, Low carbon steel (for cast iron)
  • 22ddLL: Stud, Medium carbon steel (for cast iron)
  • 23ddLL: Stud, Low carbon steel (for light alloy)
  • 24ddLL: Stud, Medium carbon steel (for light alloy)
  • 82-5ddLL:
  • 82-6ddLL:
3- Machine Screws
  • 31ddLL: Machine screw, Pan head
  • 32ddLL: Machine screw, Flat head
  • 33ddLL: Machine screw, Oval head
  • 34ddLL: Machine screw, Truss head
  • 35ddLL: Machine screw, Blind head
  • 36ddLL: Machine screw, Hexagon head
84- Pointed Machine Screw
  • 84-1ddLL: Pan head
  • 84-2ddLL: Flat head
  • 84-3ddLL: Oval head
  • 84-4ddLL: Truss head
  • 84-5ddLL: Blind head
  • 84-6ddLL: Hex head
5- Other Screws
  • 51ddLL: Tapping screw, Pan head
  • 52ddLL: Tapping screw, Flat head
  • 53ddLL: Tapping screw, Oval head
  • 54ddLL: Tapping screw, Truss head
  • 57dLL: Wood screw, Round head
  • 58dLL: Wood screw, Flat countersunk head
  • 59dLL: Wood screw, Oval head
    a) pan, b) button, c) round, d) truss, e) countersunk, f) oval
6- Rivets
  • 61ddLL: Rivet, Round head
  • 62ddLL: Rivet, Flat countersunk head
  • 63ddLL: Rivet, Flat head
  • 66ddLL: Rivet, Tubular flat head
  • 67ddLL: Rivet, Tubular flat countersunk head
  • 68ddLL: Rivet, Split oval head
87-11 Flared Nuts
  • 87-111dd Inpe-ted
  • 87-112dd Standard
87-12 Connectors
  • 87-121dd Straight
  • 87-122dd Elbow
  • 87-123dd Elbow
87-2 Hose Clamps
  • 87-211dd: A
  • 87-211dd: B
87-31 Clevis
  • 87-311dd: A?
  • 87-312dd: B?
  • 87-313dd: ???
9-11 Hex Nuts
  • 9111dd: Hexagon nut, low carbon steel
  • 9112dd: Hexagon nut, medium carbon steel
  • 9113dd: Hexagon nut, Low, low carbon steel
  • 9115dd: Hexagon nut, High, low carbon steel
  • 9116dd: Hexagon nut, High, medium carbon steel
  • 9117dd: Hexagon nut, Recess, high, low carbon steel
  • 9118dd: Hexagon nut, Recess, high, medium carbon steel
  • 9119dd: Hexagon nut, Recess, low, low carbon steel
  • 9110dd: Hexagon nut, Recess, low, high carbon steel
9-12 Lock Nuts
Self-locking nut (stopper nut)
  • 89-121dd: ???
  • 89-122dd: ???
  • 9123dd: Self-locking hexagon nut, N, low carbon steel
  • 9124dd: Self-locking hexagon nut, N, medium carbon steel
  • 9125dd: Self-locking hexagon nut, low, low carbon steel
  • 9126dd: Self-locking hexagon nut, low, medium carbon steel
  • 89-127dd: ???
  • 89-128dd: ???
9-13 Square & Wing Nuts
  • 9131dd: Nut, Square
  • 9134dd: Nut, Wing (forged)
  • 9135dd: Nut, Wing (sheet)
89-14 Hex Weld Nuts, Tapping Discs, Plate Nuts
  • 89-141dd: ?
  • 89-142dd: ?
  • 89-143dd: Tapping Disc A?
  • 89-144dd: Tapping Disc B?
  • 89-145dd: Plate
9-15 Washers
  • 9151dd: Washer, Sring lock medium
  • 9152dd: Washer, Sring lock thick
  • 9154dd: Washer, Plain standard
  • 9155dd: Washer, Plain large
  • 9158dd: Washer, Finish
9-16 Tooth-lock Washers
Tooth Lock washer (shakeproof)
  • 9161dd: Washer, toothed inside ratchet (outside dia. msall)
  • 9162dd: Washer, toothed inside ratchet (outside dia. large)
  • 9163dd: Washer, toothed outside ratchet
  • 9164dd: Washer, toothed 80° countersunk
  • 9165dd: Washer, toothed 90° countersunk
  • 89-166dd: Washer, ???
  • 89-167dd: Washer, ???
  • 9168dd: Washer, toothed both side ratchet
9-17, 89-19 Nut Retainers
  • 9-171dd/89-191dd: Nut retainer, Both shanks round hole
  • 9-172dd/89-192dd: Nut retainer, One shank round hole
  • 9-173dd/89-193dd: Nut retainer, Both shanks long hole
  • 9-174dd/89-1914dd: Nut retainer, One shank long hole
  • 89-195dd: ????
9-2 Pin & Key
  • 921dLL: Cotter pin
    • 6 Semicircular key
    • 8 Parallel key
9-31 Thread Plugs
  • 9311dd: Plug, threaded, square head taper thread
  • 9312dd: Plug, threaded, square hole taper thread
  • 9312dd: Plug, threaded, recessed taper thread
  • 9313dd: Plug, threaded, hex head taper thread
  • 9314dd: Plug, threaded, hex head parallel thread
9-32 Grease Nipples
  • 9321dd: Grease nipple, Straight
  • 9322dd: Grease nipple, 67.5°
  • 9323dd: Grease nipple, 90°
9-4 Electric Parts
  • 94*1dd: Electric parts
9-5 Rubber Parts
  • 95*1dd: Rubber Grommet
89-6 Spring Nuts
  • 89-631dd: A1 type
  • 89-632dd: A2 type
  • 89-641dd: B type
  • 89-651dd: C type
  • 89-661dd: D1 type
  • 89-662dd: D2 type
  • 89-663dd: D3 type
  • 89-664dd: D1 type
89-61 Push-on Spring Nuts
  • 89-611dd: A1 type
  • 89-612dd: A1 type
  • 89-613dd: B type
  • 89-614dd: C type
Dimension Digits
Distinction by alias dimension of diameter and width. Each number may be either a size, inch dimension or metric dimension.
  • 01: #1, 1/16", 1mm
  • 02: #2, , 2mm
  • 03: #3, 3/32", 3mm
  • 04: #4, 7/64", 4mm
  • 05: #5, 1/8", 5mm
  • 06: #6, n/64", 6mm
  • 08: #8, 5/32", 8mm
  • 09: ,,9m
  • 10: #10, 3/16", 10mm
  • 12: #12, 7/32", 12mm
  • 13: ,, 13mm
  • 14: #14, 1/4", 14mm
  • 15: ,5/16", 15mm
  • 16: #16, 3/8", 16mm
  • 17: ,7/16", 17mm
  • 18: ,1/2", 18mm
  • 19:, 9/16",
  • 20:, 5/8", 20mm
  • 22: ,3/4",
  • 24: ,7/8",
  • 26: ,1",
  • 28: ,1-5/8",
Also add 30, 60, or 50 to above.
Length Digits
LL as shown above:
  • 07: 1/4 inch
  • 10: 3/8
  • 13: 1/2
  • 16: 5/8
  • 19: 3/4
  • 22: 7/8
  • 26: 1 inch
  • 28: 1-1/8
  • 32: 1-1/4
  • 35: 1-3/8
  • 38: 1-1/2
  • 41: 1-5/8
  • 44: 1-3/4
  • 48: 1-7/8
  • 51: 2 inch
  • 54: 2-1/8
  • 57: 2-1/4
  • 64: 2-1/2
  • 70: 2-3/4
  • 76: 3 inch
Suffix
For parts that have surface finishing or cotter pin hole, symbols showing these proceedings are added at the end of the part number.
Two digits mean it has a cotter pin hole. Single digit: No cotter pin hole.
  • 1: Zinc cadmium coated
  • 2: Chrome coated
  • 3: Copper coated
  • 4: Phosphoric acid coated
  • 5: Brass
  • 6: Copper
With Cotter Pin Hole
  • 10: surface not processed
  • 11: Zinc cadmium coated
  • 21: Chrome coated
  • 31: Copper coated
  • 41: Phosphoric acid coated
  • 51: Brass
  • 61: Copper
