Filters
Revision as of 05:17, 28 July 2009; view current revision
Categories: Engine Control Fuel And Exhaust System | Fuel System | Engine Lubrication System
http://www.rockauto.com
Air Filter
  • BOSCH 73202 $4.82 USD
  • FRAM CA353 $4.87 USD
  • BECK/ARNLEY 0428219 $5.35 USD
  • WIX 42906 $5.53, ACDELCO A392C $5.64 USD
Air Breather Filter
  • BECK/ARNLEY 0421396 $1.63
Fuel Filter
  • FRAM G3359 $2.54 USD
  • WIX 33053 $2.54 USD
  • BECK/ARNLEY 0438002 $2.90 USD
  • ACDELCO GF466 $3.05 USD
  • BOSCH 71909 $2.33 USD
Oil Filters
Australia:
  • Z145A
  • Z37
http://www.rockauto.com ELEMENT-oil filter, cartridge. Threads: 3/4-16 UNF, Outside Diameter: 80
  • PRO-TEC 150 $2.43, BECK/ARNLEY 0418723 $4.41, BOSCH 72133 $4.41, WIX 51361 $4.67, ACDELCO PF34 $4.88, FRAM PH3639 $6.00
TIP: Use a Ford oil filter #F-1 on your 1200. You only need to use a rotary grinder to grind 1/4 inch off the engine boss. The rotary bit cuts cast iron like butter. Then it fits.
  • bigger capacity
  • In the US, it is less expensive than the small "import" filter
Pretty much any A-series filter fits. Or any with the same threads and diameter. Few are too long for the A12.
Original Length: 145, replaced by 115 length
  • Nissan: 15208-H1010 115 height (formerly: 15208-13211 , 15208-13212 145 length)
  • Tokio FL-208(Y) 1300, 1500 C-201
  • FRAM ExtraGuard PH3639
  • Purolator #L30042
  • Deutsch #D601
  • Purolator PER42 (DATSUN,TOYOTA)
  • Purolator L30042
  • Pennzoil PZ8
  • Champion PH2822,2825
  • AC PF1026 (?)
Newer A-series filter PN 15208-H8920 (Length: 130)
  • Tokio FL-208
  • C-208
  • CKO-1218
  • SP-842
  • FC 208
  • 15208H8923
  • T-3135
NISSAN SUNNY,CHERRY (Length: 100)
  • FL-207
  • 15208-H8916
  • 15208-H8911
  • 15208-H8994
  • SP-929
  • 15208-H8917
  • 15208-H8912
  • 15208-H8905
  • 15208-H8904
  • 15208-H8903
  • 15208-H1011
  • 15208-H1010
  • Fram ExtraGuard PH3682
  • Fram ToughGuard TG3682
  • Fram DoubleGuard DG3682
  • Fram X2 XG3682
  • Purolator L24457
  • Pennzoil PZ27
  • Champion PH2827,2903 NISSAN,SUBARU
  • AC Delco PF8903
  • Wix 51361
  • Champ PH2827
spin-on oil filter used on Nissan 200SX 4 cyl. 1.8L, 2.0L F.1.,& V6 3.0L F.1. engs., 300ZX V6 3.0L eng., M-10 Sedan 4 cyl. 2.0L F.1.eng, Maxima V6 3.0L F.1.eng, Micra 4 cyl, 1.2L eng., Pathfinder V6 3.0L F.1.eng.,Pickups V6 3.0L F.1.eng., Stanza 4 cyl. engs. Van 4 cyl. 2.4L F.1.eng.,Subaru 4 cyl. 1.6L & 1.8L, XT-6 Turbo 6 cyl. 3.0L Turbo. (Replaces: Nissan 15208-H8903; Subaru 15208-AA000) Equivalent: AC: PF1232 CHAMP: PH2827 FRAM: PH3682 MOBIL: MO-4457 MOTORCRAFT: FL-839 NAPA: 1361
B210, B310, F10
  • Fram ExtraGuard PH46
  • Purolator L10168 (Audi 5000 Turbo)
  • AC DuraGuard PF34: PF34 #6437982 FITS: 74-82 DATSUN F10,210,B210,310; 78-80 FORD FIESTA L4-1.6L; 71-73 PINTO L4-1.6L; 72-75 CHEV LUV TRUCK; 83-90 MERCEDES-BENZ 4 CYL; 70-79 SUBARU; 86-90 TOYOTA VAN 2.2L, 69-80 W/KC, RC ENGINES, 81-84 STARLET, 84-85 TERCEL L4-2.0L. THIS FILTER REPLACES FRAM PH2825, PUROLATOR PER64, WIX 51034 & MOTORCRAFT FL13
