Late-model Electronic Distributor. For A12 in Sunny Truck. Made by Mitsubishi. Fitted by factory to Datsun 1200.
22100-95W10
This is fitted to Datsun 1200 trucks from October 1989 through end of production in 1994. It is a nice unit with the transistor unit mounted in the distributor body, under the distributor cap.
- 22020-G5111 TRANSISTOR IGNITION UNIT [fits inside distributor]
- B2235-U7410 TAPE-SEAL, DISTRIBUTOR 7510- [a roll of tape]
- superceded by 22235-U7400 $3.39 USD
- 22301-95W10 CONTROL ASSY-VACUUM
- 22023-G5110 UNIT-SETTER
- 22201-22010 SCREW 7510- [fixing timing plate to distributor]
- 22180-71200 SEAL-O RING [distributor to engine block] $4.25 USD
- 22101-95W10 HOUSING ASSY-DISTRIBUTOR
- Condensor: None used
- ? 22107-95W10 GOVERNOR SET-DISTRIBUTOR
- 22115-95W10 SIGNAL-ROTO ASSY
- 22109-52H60 WEIGHT-GOVERNOR
- 22127-95W10 SPRING-GOVERNOR
- 22136-77A11 PLATE ASSY-BREAKER
- 22132-95W10 CAM SET
- 22229-95W10 SIGNAL SET
Cap & Rotor
- 22162-78A10 CAP ASSY-DISTRIBUTOR $27.36 USD
- 22185-95W10 PACKING [seal, cap to body]
- ? 04136-00211 SCREW
- 22157-23G15 ROTOR-HEAD $6.88 USD
Cap fits North America models:
- 1988-1990 Nissan Sentra with Mitsubishi distributor
- Oreillys.com E16 or GA16 Sentra
- Master Pro C672
- BWD C672
- Beck/Arnley 1746918
- Niehoff Ultra WA468A; Pro-Power WA468ACS
- Bosch 03320
- Standard Motor Products JH180
- AC/Delco E338A
- 1987-1988 Nissan Pulsar NX
Bosch 03320 CAP fits North America models:
- Nissan 1983-1994
- 1989-1990 Nissan 240SX
- 1990-1994 Nissan Pickup
- 1983-1990 Nissan Pulsar NX
- 1991-1993 Nissan NX
- 1984-1994 Nissan Sentra
- Subaru 1987-1991
- 1988-1989 Subaru DL
- 1990-1994 Subaru Loyale
- 1987-1989 Subaru GL
- 1987-1989 Subaru RX
- 1987-1989 Subaru GL-10
- 1987-1991 Subaru XT
- Suzuki
- 1989-1994 Suzuki Swift
